Shut down when boosted?
Old Jul 6, 2010 | 01:11 PM
Tyme2Breathe's Avatar
Default Shut down when boosted?
I'm running a newly boosted D16Y8 @ 5 PSI with NGK Iridium IX Plugs. It's completely stock otherwise. My problem is that when the boost kicks in the RPMS bog down, causing erratic IDLE. If I apply any gas the car shuts off. Once I restart the engine the erratic RPMs disappear. Anyone heard of this? Can you point me in the right direction?
Old Jul 6, 2010 | 01:21 PM
roadsqueegy95's Avatar
Default Re: Shut down when boosted?
Tuned?
Old Jul 6, 2010 | 01:24 PM
No tune. Turbo was was installed about three weeks ago. It ran fine up until Mon.
Old Jul 6, 2010 | 02:13 PM
EsotericImage's Avatar
Retired Moderator
Dude, you cant just slap a turbo on and expect it to run right.. I see you need alot of research and maybe soon a new engine.
Take out the iridium's, throw in NGK 4091's
Convert to OBD-1 and get a tune!
Old Jul 6, 2010 | 03:01 PM
phaphon's Avatar
true you need a tune should fix the problem mines bog when boost kickd it too the cause was my car running to rich
Old Jul 6, 2010 | 04:07 PM
Deff get it tuned asap
Old Jul 6, 2010 | 05:29 PM
Gunmetal_B20_Hatch's Avatar
this is sig worthy... someone do it.
EDIT: fck it, I will.
Old Jul 6, 2010 | 06:20 PM
OK...I ordered the NGK 4091 Plugs from SummitRacing.com, unfortunetly none of the local auto stores carry them around here. I will get it tuned ASAP! Thanks for your help guys.
Old Jul 6, 2010 | 06:35 PM
I hear you on no local stores carrying the plugs. Theres only 1 place that carrys them around me. I usually buy them out ever oil change, just because they only ever have like 8 plugs in stock!
Old Jul 6, 2010 | 06:45 PM
While we are on the subject of turbos....I was wondering if anyone has any recommendations for motor oils to use ( I.E. weight 5W 30 10W 40 ETC. Eneos, Torco, Royal Purple)
Old Jul 6, 2010 | 07:01 PM
phaphon's Avatar
i use cheap oil right now just because im still tryna figure out where my oil has been going i made a homemade catch can hope thats the problem...but yeah post dyno results plz..kinda sad out of three b16 turbos mines is the slowest one aftertuned but two of my exhuast valves were a little tight
Old Jul 6, 2010 | 07:05 PM
I hope to get the tune done on FRIDAY, I will post the results.
Old Jul 7, 2010 | 05:38 AM
Retired Moderator
I use 10-40 on my car. I change it every 1000 miles. So as long as it has the "approved for gasoline engines" stamp, its all just about the same (conventional oil)
But make sure you change it every 1000 miles.
Old Jul 7, 2010 | 07:06 AM
apexi_rsx's Avatar
you should be running BKR7E NGks... you can not run stock plugs u need colder plugs!!!!!!!!!!!!!!!
Old Jul 7, 2010 | 11:37 AM
Retired Moderator
^^ already been covered dooder.
Old Jul 8, 2010 | 05:35 PM
phaphon's Avatar
cool cant wait to see dyno results...i was suppose to get a retune soon but blew my rings =( hahha
bowtieboy911
Engine Management and Tuning
Jun 4, 2011 04:32 AM
crx6662
Feb 19, 2009 05:19 PM
focuz_btch
Jan 23, 2009 08:29 PM
vangc6780
Apr 9, 2006 04:35 PM
turb
Sep 1, 2003 04:46 AM
