Help with boosted d16z6 in limp mode?
Old Jul 6, 2010 | 06:18 AM
Akdmks187's Avatar
Icon2 Help with boosted d16z6 in limp mode?
Hi guys iv tried searching for and found alot of people with some what of the same problem but i cant seem to fix it.
The problem is that it wont let me move past 5000rpm it sounds like it hits a rev limiter. It was giving me the speed sensor code so i went and changed it and it worked for about an hour and was letting me go past 5000rpm. Then the speed sensor and gauge stopped working and back to ****, but every now and then the speedometer will jump like it wants to start working. I believe the speed sensor is one that was spliced in if that matters. Iv checked all the wiring and behind the cluster to see if it was plugged in all the way. Any type of help will be greatly appreciated.. Any questions let me know pls, id really like to solve this without having to take it to a shop.
Old Jul 6, 2010 | 06:36 AM
joexiong's Avatar
Default Re: Help with boosted d16z6 in limp mode?
i'm not sure on this, but it might be your ecu too. cause i once i bought an chipped ecu in the same limp mode. check your ecu if anything looks blown.
Old Jul 6, 2010 | 06:44 AM
ChokolAwt's Avatar
what's your ecu chipped with?
what's your launch control set at? if the speed sensor goes bad... wouldn't your computer think it was stopped, hence the launch control kicking in?
Old Jul 6, 2010 | 06:45 AM
Akdmks187's Avatar
i have a s300 i dont think its blown but im gonna try a p28 and see if anything changes
Old Jul 6, 2010 | 06:58 AM
joexiong's Avatar
idk some ****er from ND did it. it was on chrome i believe. he kept sending me new chips, but never a new ecu so it was always in the same limp mode.
and it couldn've have been the speed sensor cause i had my stock virgin p28 too, and when i plug that in it's fine. just becareful who chips your ecu, cause it might be an poor soldering skill.
Old Jul 6, 2010 | 10:52 AM
Akdmks187's Avatar
bump.. still have the same problem when i switch ecu
Ruben19
Engine Management and Tuning
Sep 1, 2011 11:08 AM
nnmewes
May 10, 2009 12:39 PM
civicx
Sep 26, 2005 11:20 PM
HapaHaole
Jun 26, 2001 07:25 AM
