My battery box.
I am planning on moving the battery in eddy to the trunk so being the hardcore DIYer I am I decided to make my own box. I had originally planned on using aluminum but I read in a rule book here --> http://www.asnw.org that battery boxes have to be non conductive to be legal so I figured I try something different. I started looking around our shop and I found a whole bunch of sheets of airplane floor panel material that boeing gave to us a while ago (they give us lots of stuff for some reason). This stuff is 3/8" thick mylar (sp) honeycomb with woven kevlar on the outside (an engineer out at boeing told me they use the same processes to make the floor panel as indy/f1 teams use to make nosecones). It has the highest stiffness to weight ratio of any material I have ever worked with. I think a whole sheet weighs about 6 lbs (4'x8') and has no flex whatsoever. So I made a battery box out of it. I bent some scrap alum up and glued it all together with some polyurethane construction adhesive (sp). It is obviously unfinished and very crude looking at the moment. I will have a top made out of the same stuff and sealed by a strip of 1/2" one sided foam. I will drill some holes and use grometts (sp, I hate spelling) for the cables and the vent tube. I am undecided on how I will hold the top on, I'm thinking some little destacos or something, I'll see what we got.
I will clean up the excess glue and paint the whole thing black. What do you guys think? Is this a bad idea? Good? any suggestions? Also, is it safe to ground to the mounting bolts of the box? Should I run a ground wire up to the front stock ground location? Please tell me what you think, good or bad.
Ben
Edit: the box weighs 2 lbs at the moment.
[Modified by Ben Ogle, 6:57 AM 9/15/2002]
Ben
Looks good. I was planning a similar project sor the near future. I don't have access to aircraft-grade materials
but I have gone to a local plastics company and looked at various types of sheet plastic. I think ABS or Nylon will work fine.
I plan to epoxy it together instead of using screws so I can keep the walls thinner to save weight. I am going to use a compact dry-cell battery so it will lay down in the box, and the whole thing will fit in the spare tire well, under the floor board.
I was thinking about using some sort of acrylic top, but I'm not sure yet. And I was thinking about several latches around the top like you would find on the front of a tool box. What are the faseners you are reffering to?
I am also curious if I need to ground the battery back to the front, or if I can just pick up a good conneciton to the chasis in the trunk.
How do you plan on connecting the new battery wire to the existing leads that come of the terminal under the hood? I haven't figured that one out yet. There are a couple wires that would need to be crimped together, which might get a little messy. Is there a crimp-on "post" that you could just use the existing terminal with?
but I have gone to a local plastics company and looked at various types of sheet plastic. I think ABS or Nylon will work fine.I plan to epoxy it together instead of using screws so I can keep the walls thinner to save weight. I am going to use a compact dry-cell battery so it will lay down in the box, and the whole thing will fit in the spare tire well, under the floor board.
DeStacos are like the fastners on a tool box but more heavy duty (and more weight).
For the power wire I was thinking of something like a stereo distribution box mounted in the engine bay (like the guys with subs use), btu I am also not sure.
for your project, hope it goes well.
Marine boxes cost money and I am cheap. I also like to make things myself.
ben
for your project, hope it goes well.Marine boxes cost money and I am cheap. I also like to make things myself.
ben
I'm familiar with that stuff - we used to buy pieces of scrap materials from Boeing's surplus outlet to make skateboards. That didn't work, as I recall, but it seems like a good material for that use... Interesting experiment!
Kirk
Kirk
