overheat wats the deal
Old Jul 2, 2010 | 09:31 AM
Shaw14's Avatar
Default overheat wats the deal
so i replaced a head gasket on a 1993 civic 1.6l drove around all day then next day it over heats again pressure rising coolant tank over flow but im noticing my cooling fan not coming on ive replaced both coolant temp sensors and the fuse and relay whats the deal why am i over heating again?
Old Jul 2, 2010 | 09:55 AM
apexi_rsx's Avatar
Default Re: overheat wats the deal
check your wiring for your fan jump the plug on your thermostat housing with a paperclip with the car key turned on not started. the fan should come on if not u need to check your wiring.
Old Jul 2, 2010 | 05:09 PM
SLURS's Avatar
try this mos def
Old Jul 2, 2010 | 05:34 PM
mark_H14's Avatar
+1 on this.. if you look on those areas this may be the problem..
Old Jul 3, 2010 | 12:16 AM
dmeconitas's Avatar
I feel you on this one. I replaced everything on my girls 98 accord and that thing still over heats. Fan, switches, relays, head gasket, water pump, radiator, hoses. So I just threw a switch on it and told her to turn it on whenever she drives. Not the best thing because its not proper but their was nothing left to replace besides doing a complete overhaul main bearings and ring etc. You can take wire and jump your fan straight to the battery to make sure it works.
jmacc8
Honda Civic (2001 - 2005)
Aug 20, 2010 11:52 AM
Boostn B20
48
Oct 18, 2008 08:08 PM
cvkid15
Jun 5, 2008 11:15 AM
efboy
May 5, 2005 02:32 AM
hybrider
Jul 23, 2002 08:21 AM
