VTEC ISSUE please help
Old Jun 30, 2010 | 10:38 AM
rquint07x's Avatar
Default VTEC ISSUE please help
Hello Fellas, 2 days ago I had an issue with my VTEC, I have a B16A SIR II swapped on my hatch. I take off the throttle for cleaning, I disinstalled the TPS and MAP sensors, when I when you put everything in its place appeared the code 7 (tps) and was out of calibration, a friend of mine helped me to calibrate it, TPS was poorly calibrated (0.47), then I went to drag race when I was burning tires using launch control and I hear the vtec activated but then I repeat the burning tires and rpm not go up to 4500 rpm and vtec did not activated. No code appeared and the oil level was correct. Yesterday I changed the solenoid for one of B18C and then calibrate the tps again to 0.5 and the engine feels good
Being miscalibrated TPS could have caused the vtec not activate and revolutions do not go up in 4500?
Please if someone had the same issue before, help me out!!!! It is very confuse.
Thanks in advance!!!!
Old Jun 30, 2010 | 12:23 PM
itsmejto's Avatar
Default Re: VTEC ISSUE please help
Replacing the tps is tricky and must be done carefully to engage the mechanical linkage correctly. 0.5v closed and 5.0v wide open, you must check it every time you remove or replace one.
Old Jun 30, 2010 | 04:26 PM
-__-'s Avatar
i thought it was 4.5v wide open? uh oh..
Old Jun 30, 2010 | 04:28 PM
rquint07x's Avatar
thanks itsmejto!!!!!!
Do you think that bad calibration on TPS was the cause of my problem????
Old Jun 30, 2010 | 05:13 PM
otek // ek.dipn's Avatar
Icon6 Re: VTEC ISSUE please help
yep
Old Jun 30, 2010 | 05:20 PM
rquint07x's Avatar
Ok I will go to drag race tonite and I will expect that my engine runs better
Thank you very much
cates_07
13
Feb 20, 2006 08:25 AM
Rywire
Dec 27, 2002 12:30 PM
MyWhiteCivic
Sep 29, 2002 11:29 AM
ATS_Antone
Sep 6, 2002 08:43 PM
89sir-9
Jun 18, 2002 11:02 AM
