I have lost V-TEC. Can someone help me???
OK, I was going over some of my datalog files and I realized that I never hit V-TEC. In it's place, I'm getting a V-TEC pressure code (code 22 on my P28 ECU). That's why my car is so damn slow. So can anyone help me? The code first starting happening when I put the turbo on and was going very fast. full throttle at 80 mph I throw the code but I'm not getting V-TEC before that either. Can someone help me? Did I tap vacuum in the wrong place? I have no idea what I did wrong. Please help.
BTW, my VTECH phone is working fine so that will save some of you guys some time.
Re: I have lost V-TEC. Can someone help me??? (inline976)
Would I need that? Not enough oil pressure? I'm serious guys. My car is extremly slow for having a turbo. Please help.
Re: I have lost V-TEC. Can someone help me??? (MyWhiteCivic)
Lost your VTEC? Hmm.. check between your seats, I know mine always falls in there
No really, check your oil level, you might be running low.
Re: I have lost V-TEC. Can someone help me??? (VTC_slow_CiViC)
Check your wires the could be bare in a spot and have shorted the solenoid out, also your ecu could be bad i had a bad one, or maybee you VTEC solinoid is clooged take it off and look at it
TERRY
TERRY
Re: I have lost V-TEC. Can someone help me??? (sleepercivic)
If you are running fish tank check valves then get rid of them and get the missing link.....when ever your check engine light comes on your car is in safe mode so VTEC wont kick in....for the fish tank check valves you might not have enough...if you are not running check valves then ohm out your VTEC solinoid to see if it is bad......just some thoughts
Re: I have lost V-TEC. Can someone help me??? (TurboDX)
I don't use check valves or a missing link. I have Hondata. Thats how I found out which code it was.
How much oil do you guys think I should put in over the normal amount?
Thanks VTC_slow_CiViC, but no luck. Maybe I left it in the house.
My $.02
Re: I have lost V-TEC. Can someone help me??? (DSF)
I'm going to pull off the solinoid tonight and check it. I'll check the wiring while I'm there. I'll post later on tonight.
"0" If your oil level and pressure are normal there should be no need for more oil. Check the solenoid wiring. Make sure you have continuity back to the ecu. Check the solenoid itself, too. Also, I did know one other person with a Hondata unit who ended up with mysterious codes (meaning the hard parts checked ok). Ended up being a bad ecu.
My $.02
My $.02
Re: I have lost V-TEC. Can someone help me??? (KAMiN)
Re: I have lost V-TEC. Can someone help me??? (rjardy)
and there were like 13 threads that week about how people vtec werent working
Re: I have lost V-TEC. Can someone help me??? (Jago)
Do you know how to fix that? What should I do? I called Hondata and they said it can't be a problem with the ECU because if it was, the code wouldn't show. How do I check for a bad V-TEC pressure switch?
