tempature guage problems?
Old Jun 28, 2010 | 04:21 PM
spens 91 Ef's Avatar
Default tempature guage problems?
ever since i have been driving this car the temp guage hasnt been working when i drive the car around it stays all the way at cold even when the car is obviously warm, but when i go on a longer drive say drive like 60 miles the temp guage will go to the top and bounce around. Is this the thermostat? or what else could it be?
Old Jun 28, 2010 | 04:24 PM
es.roadster's Avatar
Default Re: tempature guage problems?
go to a junkyard and grab a ECT. its the single wire sensor/plug under your distributor
Old Jun 28, 2010 | 04:27 PM
thatHEMIguy's Avatar
wouldnt hurt to throw in a new temp sensor
Old Jun 28, 2010 | 04:28 PM
ek_bape's Avatar
Old Jun 29, 2010 | 04:56 AM
netfreak's Avatar
Could also be the cluster. Mine was constantly pegged at the top but sometimes floated to half. Swapped cluster and now it works.
Old Jun 29, 2010 | 06:48 AM
88whitehatchidaho's Avatar
just ground out the wire that goes to the ECT sensor under dizzy. If your gauge pegs to hot your cluster and wiring is good, and its most likely the sensor itself.
Old Jul 1, 2010 | 04:20 PM
i dont think its the cluster had the stock 1 in before then swapped it out for a auto cluster with a tach, i think i pulled 1 out of a z6 head a while ago but ill double check i know i had to redo the wiring for the sensor
Old Jul 2, 2010 | 03:34 AM
WigginsSiR's Avatar
you could put in a aftermarket temp guage
Old Jul 2, 2010 | 09:05 PM
ill probaly order a brand new 1 from honda and check the wiring
Old Jul 3, 2010 | 12:30 PM
gringo7718's Avatar
this is the best advice. Do the test. Don't just start spending money to replace parts if you don't know what is wrong.
Old Jul 3, 2010 | 06:07 PM
ok will do, anybody know the part number for the sensor?just in case
Old Jul 5, 2010 | 11:25 AM
i grounded the wire and my gauge didnt jump up so i decided to pull my harness and check all the wiring i knew it was mest up i ripped some sensor of by accident but in these pictures its the owner before me's work
Old Jul 14, 2010 | 04:40 AM
unknownally's Avatar
My CEL is throwing a code 6 and my brother checked the wiring for me. He said it looked like someone used a speaker wire...???
Not sure what that means. How can I fix this?
Old Jul 14, 2010 | 08:13 AM
wheelgarage's Avatar
You might want to consider replacing that harness. Local junk yards have them...
It is recommended to do the test, get that dusty meter out of your tool box and put it to work. I had the issue of the gauge "pinged" at H when warmed up. Did the tests and confirmed that the gauge was bad. From discussing the issue with the past owner (sister), I found out that there were electrical dash issues AFTER some stole the radio.
Old Jun 9, 2012 | 12:54 PM
EGboy89's Avatar
i have the same issue replace the ect "sensor" still not working, any way of checking if the ect "sender" is working before jumping to wire issues??
Old Jun 9, 2012 | 08:12 PM
video_voide's Avatar
i had this problem too, and as several folks have mentioned: ground the sensor.
i took a length of wire, 10gauge if i recall, stripped one end of it so i had like 2 inch of exposed copper, wound that around the very base of the threads and soldered it there. on the other end of the wire i soldered on a grounding eyelet thing and ran that up to the valve cover to the same post which is grounded to the chassis.
works now.
Old Jun 10, 2012 | 08:41 AM
villc713's Avatar
Three ways of fixing this getting a aftermarket tempature gauge, redo the wiring yourself, or just swap out the harness remember it is a difference between dpfi harness's and mpfi harness's
neu-b
Aug 12, 2009 04:02 PM
NFRap1
Jan 8, 2009 08:17 PM
ef8sleepr
Mar 23, 2007 06:16 PM
92b16hatch
Dec 12, 2006 11:26 AM
C8V6C
Mar 27, 2006 09:01 AM
