temp guage not working
Old Dec 8, 2006 | 09:43 AM
92b16hatch's Avatar
Default temp guage not working
sup guys my temp guage just stopped working one day...i replaced that sensor and everything and it still isn't workin....could it be a fuse? if it is can you please tell me which one because i dont have the cover with the diagram....thanks again
Old Dec 8, 2006 | 10:51 AM
devnull's Avatar
There is no one fuse for the temp gauge, only the whole cluster.
If you have a swap start by looking at your wires and connections.
Old Dec 8, 2006 | 01:21 PM
BuddhaSiR's Avatar
Default Re: (devnull)
Are you sure you replaced the right sensor? The one for the guage is the single wire one under the distributor. If you ground that wire, your gauge should go all the way up to hot. If it doesnt your instrument cluster is no good or the wire to the cluster is no good.
Old Dec 9, 2006 | 09:56 AM
92b16hatch's Avatar
i looked at all of the connections and everything was perfect...when i turn my key the temp guage flickers a realllyyyy smalll amount, im gonna look at that wite by the distrributor....can you elaborate a little on that..?
thanks for some feedback guys!
Old Dec 11, 2006 | 12:40 PM
92b16hatch's Avatar
any other suggestions?
Old Dec 11, 2006 | 01:48 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (92b16hatch)
did u check what he said yet?
Old Dec 12, 2006 | 11:26 AM
92b16hatch's Avatar
yea, and all of the connections are good
jdm_ek_noob
Feb 5, 2014 04:57 AM
spens 91 Ef
16
Jun 10, 2012 08:41 AM
T_98 COUPE EJ7
Apr 7, 2011 11:07 AM
effin
Jan 4, 2011 05:15 PM
specie
Aug 1, 2010 01:59 AM
