97 civic coupe with SI b16a2 heating up
Old Jun 28, 2010 | 03:33 PM
h22acd5's Avatar
Default 97 civic coupe with SI b16a2 heating up
hi i have a 97 civic coupe it seems to be heating up when im sitting in traffic i commute and sometimes there traffic so it goes from quater heat to about half way after about 20 mins sitting at idle so i was wondering what your assumption maybe or any inside knowledge would be nice. thanks it has a CEL code 41 which is 02 sensor if it matters
Old Jun 28, 2010 | 03:34 PM
lobudgetr's Avatar
Default Re: 97 civic coupe with SI b16a2 heating up
Sounds like cooling fan isn't coming on to me. most likely it's the fan switch by the thermostat housing.
Old Jun 28, 2010 | 03:36 PM
h22acd5's Avatar
can i check that by turning it on and just watching the fan??
Old Jun 28, 2010 | 03:39 PM
lobudgetr's Avatar
Yeah, I would say let it sit running in your driveway after you've driven it so you don't have to wait as long for it to warm up. If the fan doesn't come on you can take the plug off the switch by thermostat housing and jump a wire in the plug to see if the fan comes on then.
Old Jun 28, 2010 | 03:41 PM
h22acd5's Avatar
ok cool thanks ill try that and let you know.
shadow4510
33
Mar 12, 2016 04:24 AM
xGeNeTiCxFuNkx
Mar 9, 2014 12:36 PM
Slayer85
13
Feb 7, 2011 11:30 AM
kustom_2323
Sep 24, 2009 05:14 PM
BeesDA6
Apr 13, 2004 05:36 AM
