need some help with d16z6 swap issues
Old Jun 28, 2010 | 03:19 AM
mjshealy's Avatar
Default need some help with d16z6 swap issues
Hey all, I just bought a 94 vx hatch with a d16z6 si swap, the guy didn't put in an evaporation canister, or hook up vacuum lines, and he didnt convert the 02 sensor to 4 wire. Can I run it at peak performance without the cqnister and vacuum lines? If not, whats the best place to find diagrams? Also, the vtec is hooked up, but not working. I'm getting code 21 and 22. Any ideas?
Old Jun 28, 2010 | 05:03 AM
farfrumugen's Avatar
Default Re: need some help with d16z6 swap issues
just do a search for a vacuum diagram for a ex or si, you will NEED the vacuum hooked up right before it will run correctly. not sure on the evap canister. youll need to convert the o2 sensor to 4 wire for it to run right as well
adam
Old Jun 28, 2010 | 07:09 AM
mjshealy's Avatar
Ok, what about the vtec? I got the ecu pinout from ffsquad, but that doesn't help me determine which wires to tie them in to.... anyone found a good writeup for a fresh vtec install? I used to find these things in search but lately it won't bring up anything relative.
Old Jun 29, 2010 | 06:07 PM
mjshealy's Avatar
ok, i ran the Orange/White wire from harness on passenger wheel well to the vtec solenoid, and the orange/purple wire to the blue wire on the vtec switch, but im still getting a CEL 21 and 22, vtec is not engaging. the o2 sensor on the car is a brand new 5 wire, but i still get a cel for it. Anyone have ideas?
Old Jun 30, 2010 | 02:46 AM
mjshealy's Avatar
please help guys, i really want to resolve these issues. The code 41 is for the Heater O2 sensor, i have a 5 wire o2 sensor but from what ive been reading it needs to be converted to 4 wire. can ANYONE help??
dpine
Nov 13, 2005 04:35 PM
Cappelle
Apr 28, 2005 04:37 PM
b18c1civic
Jan 16, 2004 12:34 PM
DevLishPlaya
Aug 1, 2003 11:06 PM
DiPPeD iN miLk Ej CoUpE
Mar 10, 2003 03:26 PM
