00 civic si barely moves no power help!
Old Jun 27, 2010 | 06:18 PM
jdmasfuk's Avatar
Default 00 civic si barely moves no power help!
Ok i was driving home my cel came on for code 4 which is a ckp (crank position senor) went into limp mode wouldnt go past 3.5k rpm.. So i found out the sensor is located in the dizzy replaced that and now they cel is off revs past 3.5k but has no power at all.. when i press the gas the car just bogs out and barely moves at all.. i have to ease on the gas to get it to go... Any ideas what to check???
What i have done:
spark plugs and wires less than 10k mi ago
new cap
adjusted the dizzy every which way dosnt help
double check the firing order
what else could it be??
Old Jun 27, 2010 | 07:23 PM
jdmasfuk's Avatar
Default Re: 00 civic si barely moves no power help!
the distributor i just got has tc-08a marked on it.. looked the number up and it says its only for 1.8l bseries engines could b the reason??
Old Jun 28, 2010 | 02:59 AM
jdmasfuk's Avatar
bump
Old Jun 28, 2010 | 05:51 AM
jdmasfuk's Avatar
any thing?
Old Jun 28, 2010 | 06:31 AM
Vindicator9000's Avatar
318 Curves, 11 miles
You have NO CEL, and it's still in limp mode?
I would re-scan it and see if it still has anything stored. I can think of no reason that a Civic would limp mode with no CEL at all.
Old Jun 28, 2010 | 06:59 AM
jdmasfuk's Avatar
no the car dosnt have a cel on.. im not for sure car is n limp mode or not it just moves REALY slow i have to ease on the gas to get it to move
Old Jun 28, 2010 | 04:00 PM
jdmasfuk's Avatar
bump
patrickstar
Oct 29, 2011 06:18 PM
ek_gsr1
Jul 23, 2011 08:07 PM
MrXclusivE
11
Jan 14, 2010 01:15 PM
supercoy101
14
Jun 7, 2009 10:46 AM
Teglessb18
Oct 3, 2007 08:53 PM
