blockguard with honed block
Hello there.!
will i have problem with the blockguard i already install to my b16a2 engine??
first i hone the block at 81,5mm
and then i put in the blockguard..
everything seems to work fine with the movement.
everything seems to be in the center when i put in the geniune headgasket.
everything seems to be fine.....
and with the headgasket geniune everything seems to be in the center...
here some pictures...
Masterl1nk
Engine Machining & Assembly
Apr 25, 2017 12:31 PM
