help!
Old Jun 24, 2010 | 09:38 PM
haze808's Avatar
Default help!
so i got this honda civic 99 si it wont start when i turn on the ignition. i dont here nothing, no cranking no nothing but when i jump start it from under the hood where the starter is with a screw driver it starts up fine and i drive it all over until i turn it off again and i gotta jump it again. this happen just today(6/24) yesterday(6/23) was working just fine..
whats the problem???
thanks in advance
Old Jun 24, 2010 | 09:47 PM
phootbag's Avatar
Default Re: help!
Without performing diagnostic troubleshooting nobody can tell you what is wrong. From what you say, I would begin figuring out why turning the ignition switch to START doesn't cause the starter to turn.
Check for battery voltage at the starter solenoid in the START position. Trace backward if voltage is not present to find the fault ( Aftermarket alarm? Aftermarket starter cut? ). If voltage is present the starter is probably broken.
Old Jun 24, 2010 | 09:58 PM
haze808's Avatar
Default Re: help!
sorry im very new to this trying to do it myself to save money but anyways
there are to voltage present at the starter. so it must be good right?
Old Jun 25, 2010 | 04:25 AM
apexi_rsx's Avatar
Default Re: help!
have you check and to make sure all your grounds are not corroded? i had a problem similar to this and i had to clean my engine ground
Old Jun 25, 2010 | 02:00 PM
haze808's Avatar
Default Re: help!
naw they're all fine
Old Jun 25, 2010 | 02:07 PM
Nichelson_Performance's Avatar
Default Re: help!
Check to make sure you have power at the small wire at the starter with the key in the start position(3rd) you will need help doing this , if not then check fuses or relays under the dash and hood. If you have power then your solenoid on the starter is bad and needs replaced
Old Jun 25, 2010 | 02:13 PM
haze808's Avatar
Default Re: help!
naw no power at the starter and ill go take a look at the relays fuses are all good
Old Jun 25, 2010 | 02:19 PM
Jimmy's Avatar
Global Moderator
Default Re: help!
https://honda-tech.com/forums/showthread.php?t=2407755
Jack Murphy
Jun 21, 2017 06:23 PM
Daku99
Jan 1, 2013 09:08 AM
battleREADYb20
Apr 30, 2009 02:36 AM
DAYUIZ
Jan 20, 2004 03:03 PM
elpermgrande
Aug 9, 2002 06:43 AM
