My '90 Accord Refuses to Start
Old Jun 23, 2010 | 08:50 AM
Beaumont's Avatar
Default My '90 Accord Refuses to Start
Hey guys,
So I've searched the forums fairly rigorously, excuse me if I am posting a repeated question, but as far as I can tell, I'm not.
Anyway, so about a year ago (as summer started), my 1990 Honda Accord starts having trouble restarting. The symptons are this:
Turns over, fires up, dies. Sometimes I'd get it to start but most of the time I'd require a jump as my battery would go dead. If I did get it started, and drove it somewhere over a short period of time (5-20 minutes) and turned it off, it'd have problems starting again until I waited another 10 minutes or so.
Well, what eventually fixed this problem is replacing the battery, it was 2 years old, but bam, no more problems. All fall, winter and spring it worked OK. I was in -37 degree weather too, and it worked like a champ.
But now as we enter in the summer again, it is having probems starting. My battery isn't even a year old... The negative side cable that hooks up to the battery is a little loose, but I think its getting a fairly good connection. It is having the same exact symptons as last time. EXCEPT this time, it seems that if anything other then a truck jumps it, it won't fire up.
Any help would be greatly appreciated. I am currently missing work today because of this and I love my honda accord and all, but this is getting ridiculous. Thanks!
Old Jun 23, 2010 | 09:18 AM
AaronRVegas's Avatar
Default Re: My '90 Accord Refuses to Start
my car was having the problem of starting and dieing immediately. it turned out to be the ignition switch. $50 from autozone. i actually dont think i tried jumping it.
i would check your ignition switch, starter, all the wiring for any cuts or abrasions, check your grounds maybe too.
also main relays have a tendancy to go out once it starts getting warm out. it probably needs to be changed/resoldered anyway even if its not the immediate problem.
thats all i can think of at the moment. if you have a haynes manual check the first chapter or whatever for common symptoms and fixes
amyshonda
Jan 10, 2020 12:29 PM
darthvader747
Nov 5, 2009 11:01 AM
AlexcustomRide
Feb 10, 2009 12:45 PM
andrew160
Aug 8, 2008 01:18 PM
MHonda06
May 16, 2008 07:04 AM
