Why is my civic Idling weird
Old Jun 22, 2010 | 10:10 AM
tundra2000's Avatar
Default Why is my civic Idling weird
My 1994 civic ex d16 is idling weird, it will rev up and down by it's self and when I drive it, it will drive by it's self like i don't even have to push the gas to keep going, and why do i have water coming out of a hose that hooks to the bottom of the throttle body, it's a hose that is connected by the thermostat housing.
Old Jun 22, 2010 | 10:27 AM
jooky5's Avatar
Default Re: Why is my civic Idling weird
would you like a link to the 7 thousand other posts about a civic with idle issues?
Old Jun 22, 2010 | 10:32 AM
delsolproblems's Avatar
You likely have a vacuum leak somewhere or else your idle is just not set properly. The leaking hose is a coolant line. Get new hose clamps for it and if it still leaks, replace the hose.
Old Jun 22, 2010 | 11:40 AM
JDM_SOHC's Avatar
Sounds to me like ur FITV (Fast Idle Thermal Valve) is shot... Which is EXTREMELY notorious in those models... Easy fix, just take it off and bypass it... Theres tons of links on here with DIY writeup's but it's really not that hard...
90CB7EX
Nov 10, 2016 04:13 PM
zemerin
Apr 4, 2014 04:56 PM
thexbrothers
Oct 9, 2013 09:27 AM
93formula
10
Aug 14, 2007 07:12 PM
civiclxb16a
11
Apr 27, 2005 06:20 PM
