NNED HELP!!96-00 CIVIC ALTENATOR PROBLEMS???
Old Jun 21, 2010 | 07:08 PM
jdmeg6r13s's Avatar
Default NEED HELP!!96-00 CIVIC ALTENATOR PROBLEMS???
HEY WATS UP PPL I NEED SOME SERIOUS HELP I JUST BOUGHT A NEW BATTERY NEW ALTENATOR,FUSEBOX AND MY CAR STILL SEEMS TO NOT CHARGE UP LIKE IF I WAS TO TAKE THE POSTIVE OFF THE BATTERY POST THE CAR SHUTS OFF AND I KNO THE BATTERYS DIENG CUZ MY HIDS ARE STROBING LIKE A POLICE LIGHT PLZ ANYONE HAD OR HAVES THIS PROBLM AND HAS A SOLUTION PLZ LMK ASAP!! ALSO THIS IS THE 3RD ALTENATOR SO FAR AND 3RD BATTERY IT KEEPS HAPPENING!!!
Old Jun 21, 2010 | 07:21 PM
Hondatherdm's Avatar
Default Re: NNED HELP!!96-00 CIVIC ALTENATOR PROBLEMS???
If you have a meter put one probe on batt post and other one at alt bolt where batt cable bolts, you should have not more then .5 v
Old Jun 21, 2010 | 07:33 PM
Former User's Avatar
Turn off the all caps, and then check whether 7.5A dash fuse 15 is blown.
And don't disconnect the battery with the engine running because this may damage sensitive electrical components.
Old Jun 22, 2010 | 12:16 AM
jdmeg6r13s's Avatar
WILL CHECK IT OUT IN THE MORNING. AND I EVEN TRYED HOOKING UP A DIRECT GROUND FROM BATTERY NEGATIVE TO THE ALTENATOR AND ONLY ONE HEADLIGHT STROBES/FLASHES BUT WHEN I USED MY BUDDYS CAR BATTERY THE LIGHTS WERE FINE BUT IM SURE ME DRIVING IT WILL JUST DRAIN THE BATTERY AGAIN.I NOTICED WHEN BATTERY GETS LOW ONE LIGHT FLASHES WHEN IT GETS LOWER BOTH FLASH THEN THE RPM METER JUMPS UP AND DOWN THEN CAR DIES AND WONT START UNTIL YOU PUT A NEW BATTERY
Old Jun 22, 2010 | 12:19 AM
jdmeg6r13s's Avatar
I KNO ITS A WEIRD PROBLEM AND VERY VERY AGGREVATING FOR ME AND EXPENSIVE I NEVER HAD A PROBLEM LIKE THIS BEFORE WITH NONE OF MY 7 HONDAS I HAD IN THE PAST
Old Jun 22, 2010 | 01:44 AM
Nichelson_Performance's Avatar
do what RonJ@HT said check the alt/speed sensor fuse, if it's blown it WILL NOT charge. also if it's blown you have a problem that is most likely to deal with the speed sensor plug or the ground junction connectors on the back of the motor.
and please turn off the caps lock lol
Old Jun 22, 2010 | 10:29 AM
jdmeg6r13s's Avatar
lol my bad and thanks you guys it was that fuse i kno i should of checked it before but i was too upset to even think about a fuse being blown i thought it was major but my car is up and running now thanks to h-t
Old Jun 22, 2010 | 10:52 AM
Your welcome, hopefully this is the only time it blows, if not then your got a shorting out problem to look for
niceprelude
Feb 26, 2017 08:03 PM
gsrpedro
14
Feb 5, 2008 01:14 PM
LSracing94
Aug 19, 2007 08:07 AM
samp
Dec 4, 2006 11:05 AM
Project X
Feb 24, 2004 05:44 AM
