battery damaged???
Old Feb 22, 2004 | 01:50 PM
Project X's Avatar
Default battery damaged???
While trying to jump my car, I had the booster cable hooked up to the +ve of the dead battery and ground on the chasis. When trying to reach the other end, I found that the 2 clamps were stuck together already. I pulled them apart them as they seem to be magneticallly attached.
I then started all over and proceed into connecting the terminals properly by first connecting the +ve of dead battery, then +ve of the running battery (other car), then -ve of the running battery, then chasis ground on the dead car.
The car started up fine and the battery recharged itself fully after a long drive.
So, did I shorten the life or damaged my battery?
Old Feb 22, 2004 | 02:43 PM
nolexforever's Avatar
Default Re: battery damaged??? (Project X)
if your battery needs to be jumped often, consider replacing the battery or have your alternator checked out...i personally wouldnt be worried if you only needed to jump the battery once.
Old Feb 22, 2004 | 02:50 PM
Project X's Avatar
Default Re: battery damaged??? (nolex7)
Ya, I just need to jump this one time because I was working on the car and I forgot how long I had the stereo and interior lights on.
Old Feb 22, 2004 | 03:53 PM
Creep's Avatar
its kinda hard to tell, but if its holding charge you should be good.
Old Feb 24, 2004 | 05:44 AM
Project X's Avatar
Default Re: battery damaged??? (Creep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Creep &raquo;</TD></TR><TR><TD CLASS="quote">its kinda hard to tell, but if its holding charge you should be good.</TD></TR></TABLE>
Yup. It's holding up the charge. Thanks.
Integ-boy
Nov 26, 2007 06:12 PM
Turbo_Mike
Apr 30, 2006 06:25 AM
Speedyturtle
Jun 16, 2002 07:12 PM
