Ignition Options (Type R swap)
Old Jun 21, 2010 | 11:57 AM
vt_hokie2008's Avatar
Default Ignition Options (Type R swap)
Background: 00 Si with 98+ JDM Type R swap
I need a new distributor. The options I'm considering are:
MSD setup: http://www.summitracing.com/parts/MS...RA&prefilter=1 and http://www.summitracing.com/parts/MSD-32349/ and http://www.summitracing.com/parts/MSD-6420/
OR
Stock: http://shop.advanceautoparts.com/web...S_786763623___ and some new wires (plugs are new)
Between those, I've heard good and bad things about MSD, the good being from a friend that races Honda Challenge with it and loves it. I've also seen on here that OEM is the way to go and leave it alone.
Basically I'm undecided and need some persuasion either way. I intend to order tomorrow as the car isn't running so hot (and it's my daily).
Old Jun 21, 2010 | 12:04 PM
Kidnkorner's Avatar
Default Re: Ignition Options (Type R swap)
A lot of racers and enthusiasts say that the stock system is great and sufficient and it is. An MSD system allows you to do something you couldn't do with the stock ignition is increase the spark plug gap a lot bigger allowing a more significant spark for a longer crank duration.
Old Jun 21, 2010 | 12:13 PM
But if you were spending money on a distributor, would you go MSD or stick to stock? The car is a daily driver right now with the intention of it being a track/play car in a year or so.
Old Jun 21, 2010 | 12:14 PM
kaiba's Avatar
STOCK
Old Jun 21, 2010 | 12:15 PM
Originally Posted by kaiba
STOCK
For what reason?
Old Jun 21, 2010 | 12:19 PM
kaiba's Avatar
You never listed the spec on the engine. So I'm gonna assume it's stock.
The car being used a DD. And will properly see minimum track time. Save your money go with stock.
Old Jun 21, 2010 | 12:23 PM
The engine is stock with only intake, header, and exhaust.
I'm not sure at this point how much track time this car will get, but once it is no longer my DD, it could be 6ish times a year
Old Jun 21, 2010 | 12:35 PM
Kidnkorner's Avatar
If I was going to do something other than stock it would be AEM coil on plug system.
Old Jun 21, 2010 | 12:46 PM
Red_Army's Avatar
you can go from dizzy to a COP system?
stay stock. besides the bad things that may happen it isn't worth it to pick up a MSD one when OEM will work more then perfect.
Old Jun 21, 2010 | 01:01 PM
cleansi's Avatar
stay oem... i went msd only return to oem. after i destroyed the dizzy.
the oem internal coil is good for pretty much as much pump gas will allow until detonation just keep your money
have heard countless times from other tuners with same advice
Old Jun 21, 2010 | 01:46 PM
Kidnkorner's Avatar
I would definitely do the MSD wires, iridium plugs, cap, rotor at a minimum
Old Jun 21, 2010 | 02:14 PM
98civdx's Avatar
Master Detailer
Keep it oem, no need to spend all that money for stuff that wont do anything.
Ngk plugs wires, stock dizzy.
Old Jun 21, 2010 | 02:42 PM
Kidnkorner's Avatar
I despise the word "dizzy" when referring to a distributor, so ghey.
Old Jun 21, 2010 | 04:23 PM
98civdx's Avatar
Master Detailer
ok?
Old Jun 21, 2010 | 06:16 PM
Kidnkorner's Avatar
Originally Posted by 98civdx
ok?
bobbyeg6
Feb 21, 2010 12:44 PM
Domo_Arigato
Jun 20, 2009 08:31 PM
92HB_HB
Apr 7, 2004 03:50 PM
^jefs0ng
Oct 28, 2003 02:53 PM
