modifying stock GSR shifter
Old Sep 13, 2002 | 11:23 PM
Cat's Avatar
Cat
Default modifying stock GSR shifter
ive heard of people modifying their stock shifters to make them shorter in shifts and in height, how is this done?
Old Sep 13, 2002 | 11:31 PM
PoW3l2BaN's Avatar
Default Re: modifying stock GSR shifter (Cat)
by making the ball on the shifter a lil higher than stock...it requires cutting and welding...it'll cost you the same as one of those cheap shifters on ebay....thing is that the two cuts have to be parallel to each other or else the shifter will sit crooked when installed...good luck!
Old Sep 13, 2002 | 11:46 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: modifying stock GSR shifter (PoW3l2BaN)
skunk2 short shifter
Old Sep 14, 2002 | 12:01 AM
Cat's Avatar
Cat
where could i get it cut and welded?
Old Sep 14, 2002 | 09:01 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Here's how you do it:
http://www.geocities.com/~turbotage/...t_shifter.html
Old Sep 14, 2002 | 04:35 PM
PoW3l2BaN's Avatar
a friend of mine got it done from another friend at the MCRD hobby shop....dont follow that link cause you have to add to your shifter and therefore might have clearance problems with your exhaust....if you wanna see how it feels...hit me up..im in san diego too and i can introduce you to my friend whose car the shifter is on...email me..thanks!
Old Sep 14, 2002 | 06:29 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
What people used to do is just use a hacksaw and cut off the top part of the shifter where the **** screws on to. Be sure to leave some space before the curved part or you won't have any area for the shift **** to re-attach to. Then get a MOMO type shifter that uses screws to hold it in place since the threads are gone. And there you have it, a low-buck short shifter. It's a lot less hassle than having to re-weld parts. If you are going to go that far, just buy a short shifter and don't waste your time. I'd recommend a billet steel as opposed to a billet aluminum shifter. The aluminum shifters have been known to break. Skunk 2 or Neuspeed are the best steel ones, maybe the only ones?
Old Sep 14, 2002 | 06:32 PM
Community Builder
I don't think that guy that made that how-to had any problems with his shifter. for telling people to not follow that link.
Old Sep 15, 2002 | 07:49 AM
StockTeg's Avatar
My friend can weld mine for free, but I choose not to shorten it. I like stock height.
Old Sep 15, 2002 | 08:22 AM
TimoneX's Avatar
New User
Default Re: modifying stock GSR shifter (StockTeg)
To each his/her own of course...but a shorter shift rox. It's not like the teg has a really long throw stock, but there is no downside to a shorter shifter, assuming it's done properly. I have one of the cheapo billet alluminum ones, I can't see breaking it ever, unless you were driving like an ape...in which case I'd have little sympathy. Watch now I'll break mine and have to eat those words.
Old Sep 15, 2002 | 08:27 AM
Gee3's Avatar
Default Re: modifying stock GSR shifter (TimoneX)
I agree! I have one too and I question how hard people shift to be able to break the shifter.
Old Sep 15, 2002 | 10:30 AM
gsrvtec95's Avatar
I just installed a Konig short shifter I found on ebay. and now it feels like its hard sometimes grinding 4th gear and I will somties grind second if shifting fast. anyone heard of this. I also spaced out the shifter where it bolts inthe linkage to take upthe space
Old Sep 15, 2002 | 10:35 AM
ebelp's Avatar
Default Re: modifying stock GSR shifter (Gee3)
Save time and money. Buy a real short shifter. B&M=
Old Sep 15, 2002 | 03:53 PM
PoW3l2BaN's Avatar
Default Re: modifying stock GSR shifter (ebelp)
My friends custom shifter has the **** at stock height and the throw is only about an inch....its impossible to miss a shift that way...and the stock integra shifter is stronger than the aluminum shifters out there....this same friend broke 3 of them already cause we both powershift/speed shift...and its also the weight of our *****...jdm itr **** and skun2 ***** are perfect for short shifters if you understand that whole momentum inertia crap....it works!
Old Sep 15, 2002 | 06:47 PM
TimoneX's Avatar
New User
I'm sorry to hear that...but I just can't imagine using enough force to break one.
Old Sep 23, 2002 | 05:53 AM
StockTeg's Avatar
Funny thing is that my friend who could weld a short shifter for me just broke his.
[Modified by StockTeg, 2:54 PM 9/23/2002]
Old Sep 23, 2002 | 06:15 AM
JackoliciousLegs's Avatar
Do NOT do this. The douchebag that had my GSR before me did this and the welds didn't hold, and for the longest time (i don't know if any of you remember)... i was posting asking about these weeeeeeeird things that were happening with my shifter.
Moral of the story... just buy one.
Jack
Old Sep 23, 2002 | 07:06 AM
TimoneX's Avatar
New User
Default Re: modifying stock GSR shifter (JackoliciousLegs)
Proper welds should be stronger then the original metal. If it breaks it should break NEAR a weld not at it. I'd not shorten one that way either, but if I did, I'm confident it wouldn't break at a weld.
[Modified by TimoneX, 8:07 AM 9/23/2002]
Old Sep 23, 2002 | 02:24 PM
Cat's Avatar
Cat
where could i get one cut and welded in so. cal (orange county)? how much would it cost?
Old Sep 23, 2002 | 10:28 PM
mugenracer's Avatar
what is the actual throw lenght for a stock GSR shifter, my jdm teg supposedly comes with a short shift from the factory, the throw from 1st to 2nd gear is about 3" long..is that the same as USDM GSRs?? i wouldnt mind it being a little shorter, and would consider getting a short throw kit if it is possible to shorten it
Old Sep 23, 2002 | 10:34 PM
TimoneX's Avatar
New User
Default Re: modifying stock GSR shifter (mugenracer)
Sounds about right.
Old Sep 24, 2002 | 02:47 PM
StockTeg's Avatar
Yeah, my friend's "short shifter" didn't break at the weld, but the screw that he used to weld the shifter together. My friend is one strange f*ck.
tobster
Jan 17, 2011 07:52 AM
SoyMilk
55
Mar 27, 2010 10:11 AM
661rex89si
11
Feb 3, 2009 11:52 PM
aandrewcc
Apr 23, 2007 08:47 AM
majeed11
May 12, 2003 08:50 AM
