just installed test pipe in eg few questions.
Old Sep 13, 2002 | 06:03 PM
-Whitey-'s Avatar
Default just installed test pipe in eg few questions.
car:eg
motor:b16a
exhaust:hks hiper cat back
test pipe:testprpe.com 2.5 10 3/8 long
ecu: P30
i git the test pipe from test pipe.com and wasnt happy with the welds so i ground down the old welds and re welded them to my liking then i isntalled the test pipe with new gaskets,new spring bolts and new collector donut!
took it for a quick spin around the block at about 3grand in second gear to let the motor warm up a lil pulled back in garage checked for leaks while running no leaks!
took it for a fast run around the block and when i hit about 5500(vtec crossover with v-afc my check engine light came on? i was like wtf?
pulled off to side of road killed the car started it again and it stayed off one again i hit 5500 on the way back to the garage and cel came on again?
turned it off again restarted it and nothing?
wtf is the problem?
i have no knock sensor but that dosnt throw a code.
my idel jumped from 900 to 1200 after the install also.
what is the problem?
[Modified by one_honda, 3:04 AM 9/14/2002]
Old Sep 13, 2002 | 06:31 PM
-Whitey-'s Avatar
Default Re: just installed test pipe in eg few questions. (one_honda)
hahah ok never mind i did a search and found my answer!
Old Sep 13, 2002 | 10:35 PM
SlickRedSi's Avatar
New User
What was the problem and what search did you find?
Old Sep 14, 2002 | 12:03 AM
EVIL Hx Coupe's Avatar
Default Re: just installed test pipe in eg few questions. (SlickRedSi)
Must likely the O2 sensor.
SsTiNgEr77
Oct 13, 2003 09:52 PM
SsTiNgEr77
Oct 12, 2003 09:51 PM
SsTiNgEr77
Oct 12, 2003 05:32 PM
SsTiNgEr77
Oct 12, 2003 05:31 PM
