B20 top lag and detonation
Old Sep 13, 2002 | 05:05 PM
jcivicsib20's Avatar
Default B20 top lag and detonation
I have a b20/ type r setup w/ 12.5-1 compression. Rings are still good and compression is nice. The injectors are stock and so is the head. Running a P30 ecu. I have been starting to get pretty bad detonation and the top end will sometimes lag out on me. Do i need to upgrade my injectors or what? I am running a VAFC and fuel pump w/ reguator.
Old Sep 13, 2002 | 06:07 PM
Blaze45's Avatar
Brrraaaap!
Default Re: B20 top lag and detonation (jcivicsib20)
yes (injectors) you also need
fpr
fuel pump
and some dyno time and premium gas to keep detonation away!
good luck,
Blaze
Old Sep 13, 2002 | 07:09 PM
IN VTEC's Avatar
What's your ignition timing set at?
Old Sep 14, 2002 | 11:20 AM
Default Re: B20 top lag and detonation (IN VTEC)
12 degress advanced
Old Sep 14, 2002 | 02:45 PM
IN VTEC's Avatar
So, that's 12 degrees BTDC, right?
Forgot to ask you....when do you experience the detonation? -at initial throttle tip-in? -Or, after you've gotten through a couple 1000 rpm's?
[Modified by IN VTEC, 5:47 PM 9/14/2002]
Old Sep 14, 2002 | 08:17 PM
BoostedTypeR's Avatar
"cough" ATDC...
Old Sep 14, 2002 | 09:54 PM
H2nr's Avatar
you need 310 or 440 injectors, Hondata (or AEM), and dyno time.
silver vtec
Sep 10, 2006 12:45 AM
cliff666
Feb 12, 2004 08:24 AM
VitaminB20
Oct 25, 2002 01:19 AM
jcivicsib20
Sep 7, 2002 11:22 AM
jcivicsib20
Aug 6, 2002 02:24 PM
