Spark Plugs Indicate Lean Condition Help Me Troubleshoot
Old Jun 15, 2010 | 09:02 AM
averyvm's Avatar
Default Spark Plugs Indicate Lean Condition Help Me Troubleshoot
Hey whats up guys heres the situation,
I drive a 93 Honda Civic hatch with an OBD1 B18A1 motor in it that has been rebuilt by me. Anyways a problem that I have been having for a long time is this. Everytime while driving at part throttle as soon I let of the gas the car backfires. I pull the plugs and they look very lean. (Electrodes look white and porceline is completly white.) I have a fuel pressure gauge installed and the fuel pressure is at 38-40psi during idle.
Do you guys think it would be worthwile to take off the intake manifold with the injectors still attached so that I could see the spray pattern of the injectors. Sometimes the car is also dificult to start.
Things I've checked:
Igntion timing is good
Engine timing is good
Fuel Pressure good
NGK plugs from Autozone 2.99 w/ proper gap
Old Jun 15, 2010 | 09:24 AM
lome1232's Avatar
Default Re: Spark Plugs Indicate Lean Condition Help Me Troubleshoot
Bump
Old Jun 15, 2010 | 09:43 AM
Former User's Avatar
Backfiring indicates unburned fuel in the cylinders. Did you check the ignition timing with the service connector jumped? What conditions are the plug wires, cap, and rotor?
Old Jun 15, 2010 | 11:57 AM
averyvm's Avatar
Plug wires were replaced about 3 months ago with oem plug wires. Cap and rotor are in relative good condition.
Yes you're right backfire does indicate unburned fuel. I was thinking with a poor spray pattern from the injectors there would be poor atomazation or mixing of the fuel rusulting in a lean condition. Later, that exess fuel that never got mixed well would then ignite later in the exhaust stream which causes the backfire. I dont know for sure just a hunch. bump
Old Jun 15, 2010 | 11:58 AM
averyvm's Avatar
And RonJ@HT I like your sig. That what Im trying to do.
Old Jun 15, 2010 | 12:01 PM
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Jun 15, 2010 | 03:18 PM
canadaek's Avatar
if its runing excessivly lean it can create hot spots and lead to detonation and backfires have you checked map ect sensor and O2 sensor ? all effect air/fuel ratio
Old Jun 15, 2010 | 03:21 PM
averyvm's Avatar
no havent checked the map. If I dont have a check engine light doesnt that mean the sensor is working fine?
Old Jun 15, 2010 | 06:36 PM
averyvm's Avatar
bump
Old Jun 16, 2010 | 05:40 AM
averyvm's Avatar
ttt
Old Jun 16, 2010 | 02:41 PM
canadaek's Avatar
not always. check engine light is more for emmisions then driveablity . what year make motor is it ?
eldudepapi
Apr 20, 2017 12:00 PM
Brandeno
May 31, 2015 08:55 AM
biggulpaddictio
Aug 19, 2011 05:39 AM
accord2civic2prelude
29
Nov 10, 2009 03:30 PM
nd94cx
Sep 21, 2004 07:29 PM
