ls motor into eg 4 door rear mount question
my brother got a ls motor for his 4 door eg civic and the motor is mounted in it the 2 side mounts work fine but the rear t bracket or l bracket ware its supose to bolt to the motor is about 2 inches away is there a mount he can buy to solve the problem or does it have to be cutom thanks....
well my bad i just talked to my brother and he has that t bracket so must be somthing else wrong.. and also its gotta go the right about and inch to so
well im his bro and the motors a b18b1 if it matters and the t bracket is off an ls this motor came sraight out of my buddys ek coupe and has a drivers ls mount and eg passenger mount the motor its self sits in the bay perfect it just that bracket needs to be over about two inchs i will take pics tomorrow to show what i mean.all help is apresiated - thanks
hey, by chance after your done with your ls swap in the eg sedan, could you tell me how much of a difference you feel compared to the single cam, because i also want to do this swap to my eg sedan. Thanks!
