help leaking oil
Old Jun 13, 2010 | 09:40 AM
swizz977's Avatar
Default help leaking oil
it seems like its leaking from the distributor o ring but i changed it and its still leaking what else could it be
Old Jun 13, 2010 | 09:43 AM
Former User's Avatar
Default Re: help leaking oil
Is there oil inside the distributor? OEM O-ring? Check whether the O-ring was damaged during installation.
Other possibilities are a leak from the valve cover or VTEC solenoid.
Old Jun 13, 2010 | 09:55 AM
swizz977's Avatar
no its not the valve cover or the vtec soplenoid the only place its comin from is the distributor o ring but i changed it.. and its still leakin
Old Jun 13, 2010 | 10:01 AM
swizz977's Avatar
unless its the head gasket just on the left side but i doubt it cuz my car runs fine
Old Jun 13, 2010 | 10:20 AM
Incorrect installation or wrong O-ring can cause a leak.
Old Jun 13, 2010 | 10:26 AM
swizz977's Avatar
maby ill try to get a o ring from honda
Old Jun 13, 2010 | 11:12 AM
swizz977's Avatar
wat if its the wrong dizzy
Old Jun 13, 2010 | 12:37 PM
Blzdeep's Avatar
i replaced my cam seal, and a week later my o ring on my Dizzy started leaking....get an oem, like stated and try again. make sure to clean it well.
Old Jun 13, 2010 | 02:00 PM
swizz977's Avatar
wheres the cam seal? left or right side?
Old Jun 13, 2010 | 02:04 PM
Opposite side of the distributor.
Old Jun 13, 2010 | 02:06 PM
swizz977's Avatar
well its no the cam seal since its a d16z6
Old Jun 13, 2010 | 02:27 PM
swizz977's Avatar
what does the solinoid leak from??
Old Jun 13, 2010 | 02:31 PM
chinochanginc's Avatar
also, the distributor has a seal on the inside of it. If you open the distributor and there is oil in it, the inner seal is bad. honda does not sell this is seal. they make you buy the whole dizzy. you can get it go to thepartsbin.com and look for the distributor seal... you have to dismantle the distributor to get to the seal on the inside..
Old Jun 13, 2010 | 02:47 PM
swizz977's Avatar
thats different then the o ring?
Old Jun 13, 2010 | 03:20 PM
TheCivicMafia's Avatar
Yes, its a "Non-Repairable" Unit. So they call it. You have to gut the dizzy to get to the seal.
But this isnt bad unless your dizzy is wet on the inside, and usually your car wont run or atleast not for long with oil in the dizzy.
Old Jun 13, 2010 | 04:04 PM
If there's no oil inside the distributor, the distributor seal is fine.
Old Jun 13, 2010 | 07:11 PM
swizz977's Avatar
im pretty sure its leakin from the o ring but i put a new one on.. i actually put one on and it was still leakin then i put another on.. still leaking.. but they werent from honda i dont think so idk what else it could be
Old Jun 15, 2010 | 08:27 PM
swizz977's Avatar
bumppppppp
Old Jun 15, 2010 | 08:34 PM
Linked's Avatar
its been said already man, the dizzy o-ring may have been installed improperly (oem or not)
pull it and check
Old Jun 22, 2010 | 08:41 PM
swizz977's Avatar
ok so we took the cap off today and there was no seal at all around the cap.. so we put one there it basically goes around the whole dizzy.. are there any more seals for the dizzy?
Old Jun 23, 2010 | 02:01 PM
swizz977's Avatar
bump?ppp
Old Jun 23, 2010 | 02:28 PM
CONTRADEL's Avatar
o ring could have been damaged or ripped out during the repair.
do you have any pics?
Old Jun 23, 2010 | 04:11 PM
swizz977's Avatar
which o ring??
Old Jun 23, 2010 | 04:23 PM
Nichelson_Performance's Avatar
Dumb question. Is your car turboed or does it have lots of miles making it have excessive blowby and the distributor oring is usually the first to leak from the extra pressure....try another oring, one that fits the groove nicely and takes a SMALL amount of force to push into the head, also rub some clean motor oil aruound the oring before you put the dizzy back in
Old Jun 23, 2010 | 05:30 PM
BLVD. kreeper's Avatar
wished my engine leaked instead of having burning oil
raverx3m
Jan 31, 2015 09:56 AM
user 929730482
Dec 3, 2013 09:08 PM
hatchbro
Oct 13, 2004 09:00 PM
type Gendy
11
Jul 12, 2003 11:26 AM
quikrpm'z
Mar 5, 2003 09:41 PM
