Oil leak near distributor! HElp me please also random backfire!
Hi,
Im having a bad leak near the distributor side. I got a JDM b16a w/GSR distributor. First i thought it was the head gasket because the oil sit on it(flat). I changed that out with honda OEM gasket. It still leaking
Then i check the distributor o-ring and change it. Still it leak. I dont get it. What can cause it to leak or it not my distributor that leaking. It seem to be near the distributor side. Please help!
Im also having random backfire. Code vary from 71-74. Im using Denso Sparkplug, had
BOSCH Platinum and thought it cause the backfire so i change it back to Denso(came with it).
Re: Oil leak near distributor! HElp me please also random backfire! (=GAMEOVER=)
anything else that could be leaking oil beside cam seal? i also change out the clave cover gasket also.
