Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Rear Suspension Height Problem
Old Jun 12, 2010 | 06:19 PM
Lek's Avatar
Lek
Default Rear Suspension Height Problem
I had a noise on the rear suspension of my 2010 Civic, so I took it to a Honda Service Center for inspection.
They had to remove many of the rear suspension components and re-assemble them to solve the problem. No new parts.
The suspension has no noise at all now, but the rear is sitting 20mm heigher than before and doesn't seem to be settling after a week. It's very noticable and looks strange with a high rear suspension.
I had a visual check and the springs are sitting perfect. The only thing I can think of is they tightened everything down with the car raised on the lift. Maybe they should have tightened the control arms with the car on the ground.
If I loosen the bolts in the pic and re-tighten them, will it correct the problem
Any other ideas how to solve the 20mm heigher rear.
Old Jun 13, 2010 | 02:08 PM
97emsedan's Avatar
Default Re: Rear Suspension Height Problem
Quite possible...or they made an error in the re-assembly.... have it checked either way.
Last edited by 97emsedan; Jun 13, 2010 at 02:12 PM. Reason: wrote in the wrong spot
Old Jun 13, 2010 | 04:18 PM
Lek's Avatar
Lek
I think it's nearly impossible to make an error on re-assembly. The springs look like they are sitting perfect with no noise at all.
Old Jun 13, 2010 | 05:09 PM
ajpturbopittsburgh's Avatar
I bet they just lubed the bushings.
Did you measure the height before you took it in?
Probably just an optical contusion. It wouldn't make a diff. whether or not they tightened them on the ground or not. That control arm will swing the entire length of travel regardless of how tight those bolts are..
You said they removed most of the suspension.....really there isn't much to it.
Wouldn't worry about it
Old Jun 13, 2010 | 06:39 PM
i-VTEC_DOHC's Avatar
hmm the problem could actually be the rubber seat under the springs. if you dont seat them right, the ride height will be off. theres 3 little points that stick out that are supposed to go into the matching holes on the spring seat. just check it out.
Old Jun 14, 2010 | 02:19 AM
Lek's Avatar
Lek
I have checked the ride height often since new and always had a 3 finger gap Front and rear.
Even when I fitted my bigger wheels the gap remained equal, but 2 finger gap front and 2 finger gap rear.
Since they did the work I have had 3 finger gap rear and 2 front.
This is so strange, and makes the car look weired.
I inspected the rubber seating and they appear fine, everything is flush.
Old Jun 17, 2010 | 02:56 AM
billedoc's Avatar
Check the springs, when our cars are jacked up somethings the springs like to move out of there seat or place... and I mean "sometimes".
Old Jun 19, 2010 | 07:16 PM
Lek's Avatar
Lek
I re-installed evrything and had a 4 wheel alignment done. All seems good.
Thanks for the help.
phikshin
Suspension & Brakes
Jun 11, 2009 12:03 AM
...Baker
10
Jun 10, 2006 11:53 AM
$amGD3
Suspension & Brakes
13
Apr 15, 2006 10:47 PM
