Different types of heads?
That is a pretty open ended question! The are many different heads for different series of engines, both vtec and non
Most commonly, people swap vtec heads onto non vtec blocks, because they are higher flow making more power. Added wiring, oil lines and changing your ecu would also be needed
the big difference used to be saving money. now people found that unreliable so cost has gone up for the sake of reliability. the big difference now is a block with more displacement. but thats just what I think
My last car was a 96 Civic Hatch with CRV B20Z engine. I bought a different head for it for higher flow. Called a P8R, it has oem 33mm oversize valve, same as dohc vtec heads, and also had the same flow as a vtec head, without any other modifications!
dingusjt
Honda Civic (2001 - 2005)
Jan 30, 2008 07:18 AM
powerslide360
May 15, 2004 08:52 PM
