Stripped LCA to Subfram Bolt.. What to do now?
Old Jun 11, 2010 | 08:54 PM
ej888's Avatar
Default Stripped LCA to Subfram Bolt.. What to do now?
Hey guys, I was trying to put in a tie bar and the supplied bolt for it was m10-1.5 x 100, I didn't find out until after I stripped the welded nut behind the subframe that the welded nut was 1.25 size not 1.5. So now the welded nut on the subframe is stripped but I managed to get the 1.25 bolt all the way thru. I was going to put a nut on top of the subframe welded nut becauase the welded nut on the subframe was stripped but the thread on the new bolt is also stripped so I can't even thread the new nut to the bolt. Sorry if I'm not clear but if you understand my situation what can I do now? I don't feel safe driving around knowing my LCA is held on by a stripped bolt that might pop out of no where. I was thinking going to some shop and tell them to permanently weld the bolt to the subframe nut? Thanks.
Old Jun 12, 2010 | 09:17 AM
ej888's Avatar
Default Re: Stripped LCA to Subfram Bolt.. What to do now?
bump, any suggestions?
Old Jun 12, 2010 | 09:55 AM
RedEG2's Avatar
cut the stripped nut out and weld a new nut in
drill a hole in the welded nut so theres no thread and use longer bolt with a new nut
Old Jun 12, 2010 | 10:01 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
doesn`t necessarily have to be welded back on the subframe if you don`t have access to a welder. just use the right size and pitch serrated nut.
Old Jun 12, 2010 | 11:04 AM
Red_Army's Avatar
or a castle nut. i have one missing from my trailing arm and its just some lock washers and a nut and its still there happened last year.
Old Jun 12, 2010 | 03:41 PM
ej888's Avatar
Thanks for the replies guys but every time I put in a new bolt, when it gets to the other side of the subframe, the stripped nut also strips the thread on the bolt so I can't put a nut on top of that because the nut won't thread into the newly stripped bolt.
Old Jun 12, 2010 | 08:24 PM
Red_Army's Avatar
no cut that nut out. the one welded on your subframe. THEN get a new nut to replace the one you hacked off. and apparently a new bolt too.
Old Jun 12, 2010 | 08:28 PM
98civdx's Avatar
Master Detailer
Have you tried re taping it?
I did it on my accord, totaly my fault for being in a hurry,
Pops and a tap fixed the problem.
I like my R
Aug 24, 2023 08:56 PM
stevevang
Mar 27, 2016 04:46 AM
al3e
Dec 14, 2003 04:07 PM
is3oo
Oct 4, 2003 01:48 PM
