Timing belt question?
Old Jun 10, 2010 | 09:40 AM
Tunerguy1989's Avatar
Default Timing belt question?
Has anyone removed the balancer shaft belt on the H22. I heard you can gain some extra ponys with it removed. Has anyone had any negative affects. Does the the longevity of the motor get affected. When I look at the belt it seems useless but does anyone have any experience with this?
Thanks in advance
Old Jun 10, 2010 | 12:44 PM
nus_dogg's Avatar
Default Re: Timing belt question?
Yes, you do gain some. It's been done, and I have yet to see anyone complained about theirs failing or causing problems.
I've heard slight motor vibration after the balancer has been removed but nothing major yet.
Old Jun 10, 2010 | 01:40 PM
ok great thanks for the input.
Old Jun 10, 2010 | 07:00 PM
Mr.Vtech22's Avatar
Default Re: Need help on my h22
I was driving and my timing belt jumped teeth and it sounded like a lown mower and it wouldn't go more then 3 grand so i chack the timing and it was of so i redid it everyhting new now it turns on and everything but it pops out the muffler like it's still out of time? and thoughts
Old Jun 10, 2010 | 07:07 PM
It proble is still out of time. Did you make sure that the cams and crank pulley were at tdc when you redid it. If they were then maybe a tune up might help. If not then I don't no bro.
Old Jun 10, 2010 | 08:17 PM
fastlane2's Avatar
A balancer shaft belt removal will save 1whp and thats it. I kept mine in.
yosuthnmasa
Apr 8, 2008 07:29 AM
beany
Mar 29, 2006 05:37 AM
YellowCivicE
Jul 12, 2004 06:57 AM
PrecisionH23a
Aug 14, 2002 09:22 AM
PrecisionH23a
Aug 14, 2002 05:16 AM
