JDM D15B and air conditioner
Old Jun 8, 2010 | 09:10 PM
TYNMDYS's Avatar
Default JDM D15B and air conditioner
Hey guys. This is my first post here, hope i'm not violating any rules with this post. I searched around and didn't find much, I'm just curious about something. Whenever my A/C is running on my D15, it's really slow to rev, shifts hard (because it's 5 speed and the RPM's drop really quickly) and the idle is anything but steady. I realize that the A/C takes power to run, but it literally makes my car feel dead. It's pretty quick when the A/c isn't running.
So, how bad should A/C affect my engine? It seems a little extreme.
Old Jun 8, 2010 | 09:25 PM
egsleepercivic's Avatar
Default Re: JDM D15B and air conditioner
its pretty noticeable, shifting shouldn't really be affected though
Old Jun 8, 2010 | 09:27 PM
TYNMDYS's Avatar
I just worry that my A/C compressor is either defective or garbage. The A/C blows cold, but it just seems to me sapping too much power and slowing the revs between shifts... I'm just curious if this is normal.
Old Jun 8, 2010 | 09:29 PM
D16SiHatch's Avatar
yea it's pretty sad but what sleeper said is true. i couldn't believe it myself when i felt how much running the a/c affected acceleration.
hybridmiklo's Avatar
Same happens to my del sol with a jdm zc. Feels like its dual point when the ac is on.
Old Jun 8, 2010 | 09:34 PM
TYNMDYS's Avatar
Ah. I guess I feel better now. I forgot to mention that it's an aftermarket A/C system.
Is there any way to control when my A/C compressor turns on and off? It'll blow cold, then the compressor will shut off long enough to let the A/C get noticeably warm, then it'll kick on again.
Old Jun 9, 2010 | 10:40 AM
D16SiHatch's Avatar
well that's what it's supposed to do. if you want to turn the a/c compressor off then hit the a/c button lol
Old Jun 9, 2010 | 04:13 PM
TYNMDYS's Avatar
I mean I want it to stay on constantly when I have the A/C system on... Oh well.
Old Jun 9, 2010 | 04:53 PM
D16SiHatch's Avatar
it's not designed to stay on constantly for a reason. if it did the evaporator would freeze up. once the thermoswitch see's i believe 37 degrees fahrenheit it tells the compressor to shut down. once temp comes up a few degrees it will kick back on again
Old Jun 9, 2010 | 04:55 PM
TYNMDYS's Avatar
That makes sense. Maybe the ducting has a leak from when the previous owner installed the aftermarket A/C system, because it gets almost warm before it kicks back on.
Old Jun 9, 2010 | 05:17 PM
the compressor will shut if the freon is low or if its icing up, check to see if either of these conditions are present
b20bFourDoorCivicLX
May 4, 2013 08:16 AM
jakl
11
Jun 11, 2010 08:47 AM
petrv
Jan 12, 2006 11:03 PM
MugenizedR
Nov 24, 2002 12:52 PM
