a/c not running correctly
Old May 2, 2013 | 04:02 PM
b20bFourDoorCivicLX's Avatar
Default a/c not running correctly
1.the car idles like death when the a/c is on to the point where when in neutral and i rev on the engine a bit the idle will fall on its face.
2.today its a bit hot out so i put on the a/c...it was getting cold then it stop blowing cold air then it did.but it never got cold like it should! somthings wrong! i have everything stock besides the compressor witch is a crv compressor.. but wtf could be wrong i get major drain from my a/c i dont even like to drive with it on not tell i figure this out
3.the car when driving with a/c on has been releasing some sort pressure/water "PSssHHSZZZzzZZ''not really sure what it is!
i dont want to remove my a/c i dont race my car its a DD also i drive around with my family i would appreciate some help! i have no check engine!
Old May 3, 2013 | 07:05 AM
fcm's Avatar
fcm
Old Fart
Default Re: a/c not running correctly
What year was the CRV the compressor came out of?
The "PSssHHSZZZzzZZ" you hear is most likely refrigerant blowing out either through a blow off valve or a leak in the system, it would explain you not getting cold air from the vents when A/C is on, a blow of when A/C is on indicates a restriction, and that is most likely a bad expansion valve, although can be someplace else.
A restriction would result in high head pressure at the compressor that will increase the load on the engine, explains the almost stalling. 94
Old May 3, 2013 | 07:15 PM
im not sure what year the compressor came out of, the expansion valve? the high head pressure , yea it gets alot of that. when i first took car home a/c was blowing out that stuff LOUD now its faint but more consistent and now im getting almost no cold air. something has to be bad,
and it im hoping its something faulty so i can get it repaired no money to me because this problem has been happening since i brought car home the a/c has always had a major loud on my car and has always been blowing out that ****. what the hell could it be?
Old May 4, 2013 | 07:32 AM
fcm's Avatar
fcm
Old Fart
It is refrigerant, [R134a to be specific], most likely coming from the blow-off valve on the back of the compressor. 94
Old May 4, 2013 | 08:16 AM
ThunderToe's Avatar
jkoshy18
May 27, 2004 03:31 AM
abeaujuin
May 9, 2004 08:18 PM
EX-T
Aug 18, 2003 08:01 PM
shipsaeki
Apr 17, 2003 11:06 AM
BoostedAcura
Sep 10, 2002 07:20 PM
