PWM/EBC Ready Ecu's Sold Anywhere?
Ok, here's the deal. I had my car tuned recently at a very reputable shop here in the Midwest. This is a boost by gear setup with Ectune. The tune went fine but my ecu had several resistors soldered in the wrong place for the "boost by gear solenoid" (ebc solenoid or pwm solenoid). So basically my boost is not changing in each gear. Maybe I'm an idiot but I've googled and looked around to see if Phearable or Xenocron sell ecu's already setup for boost by gear with the resistors installed correctly but haven't found anything. Anyone know if these are offered anywhere?
P.S. My tuner said he'd send me one but he was so swamped I'm almost certain it will slip his mind and I'm looking for a back up plan here if that falls through. Any help would be aprreciated. Thanks ahead of time.
Yes, we can sell you an ECU with the PWM Circuitry pre-installed in the ECU...or you can send in your ECU and we can add the parts.
http://www.xenocron.com/pwm-control-...ion-p-326.html
Best to contact me through email!
Chris
Chris
