will 88-91 civic/crx steering rack fit/work on 92-95 civic??
I have a '95 civic Ex and the only thing left of the power steering is the rack itself which is leaking due to the hacked up way the pressure line was removed by the prior owner.
I want to put a manual rack on it anyway and I have one already from my '91 CRX Si. I've heard the rack's can interchange on 88-00 civic's but I hope someone here has done it or can confirm either way for me?
I'd rather not have to find out the old fashion way if I can help it
dont think it will work why would u try any way dont be cheap go to a junk yard and pull a cx (best turning ratios) and it takes like 10mins tops
So instead of questioning my motives and assuming I'm cheap or stupid, can someone post that ACTUALLY KNOWS the answer? thank you
well i would not assume u are dumb if u did not ask a dumb ? sir i have more supention and chassis knowledge then u will ever have but take to task at hand if u are SO smart go messure the overall length from INNER tie to INNER tie rod and u will find it is not the same length and u can also measure the pic up point for the rack and find it is not the same but hay i guess it is cool to ask ?'s with out researching
I'm not trying to ****n argue w/ anybody.
I'll be finding out soon enough on my own
Part numbers don't mean ****, They'll put a different part number on something just to sell it for more or because they did no research to find out if it actually will cross reference with other makes. so again, part numbers unfortunately don't mean anything (usually anyway).
I talked to a guy last week who swore it works cause he has done it but I'm just looking for confirmation from others 1st. I'll eventually get to it myself but I currently have work to do on all 3 of my cars so the steering rack is lower on the priority list, hence the reason for the post weeks before I decide to tackle it.
Yes I Agree With You... Some PPL On Honda Tech Need To Get There Head Out There Asses Because U Dont know Everything About A Honda... PPL Come To This Website For Help Not To Be Called A Dumbass Or Get Smart *** Answers... If You Dont Have A Answer To What Someone Is Asking JUST SHUT THE *** UP
10cjennings
56
Nov 17, 2014 08:14 AM
