Crazy Speedo
Old Jun 7, 2010 | 11:18 AM
beat's Avatar
Default Crazy Speedo
My speedo's been acting wierd recently.
Couple weeks ago, once I hit VTEC, it would jump all over the place.
Now, even when Im cruising, it kinda jumps around a bit.
Any idea whats wrong?
Old Jun 7, 2010 | 11:41 AM
redGSRguy's Avatar
Default Re: Crazy Speedo
Happened to me, I thought it was the VSS, replaced that didn't help. Someone mentioned it could be the actual cluster.
In the end my problem was the plug to the vss had corroded plugs. I cut if off and wired in another connector and that fixed my problem.
Old Jun 7, 2010 | 11:42 AM
beat's Avatar
OK, I'll try to check the plugs on the VSS
Old Jun 7, 2010 | 11:53 AM
red_crx's Avatar
Too much dirt / junk in the distributer or an ignition coil going bad would cause rpm fluctuations.
Old Jun 7, 2010 | 12:14 PM
beat's Avatar
The rpms are fine though, its just the speedo
Old Jun 7, 2010 | 12:16 PM
red_crx's Avatar
Sorry I read it too fast.
I would just check the vss wires and make sure the pins havent slipped out of the plug or something.
Old Jun 7, 2010 | 01:33 PM
Henryx33's Avatar
I had the same issue. It's the (VSS). I shoved some small copper pins in the middle of the terminals and problem solved.
nicknack25
Feb 25, 2012 10:00 AM
esoterEK..
Sep 30, 2006 02:48 PM
JordanCivic
May 23, 2005 03:12 PM
JiVe
19
Jul 22, 2003 01:12 PM
Andy M
Apr 29, 2003 12:24 PM
