VSS problem
i have a 90 crx with a 95 ls cluster and i used a vss from a 93 civic.
it's been working perfectly fine until i took out my transmission.
basically my speedometer just jumps up and down.
while i reverse slowly, it jumps, when i rev, it jumps but when im still it doesn't jump.
i've tested the volts and the ground and the voltage when the vss spins and it checks out good.
is it just a faulty vss?
i took it apart and cleaned it up a bit with some brake clean, put it back together but still nothing.
the clip wasn't broken but yeah i took it out and i just put it in really snug and made sure the clip clipped on and it was fixed! Thanks for the input guys
esoterEK..
Sep 30, 2006 02:48 PM
