Running Wierd
Old Jun 6, 2010 | 08:38 PM
ToTriggerHappy's Avatar
Default Running Wierd
wat would your car do if your distributer rotor went bad
Old Jun 6, 2010 | 08:44 PM
phootbag's Avatar
Default Re: Running Wierd
Misfire or not start at all. Why are you asking?
Old Jun 6, 2010 | 08:47 PM
it drives but when driving it has a lag in the the pickup. stock d16 new sparkplugs and wires. and sometimes it will start and run for like 1 sec and shut off. then start back up after a few minutes. it has a new fuel pump and fuel filter.
Old Jun 6, 2010 | 08:49 PM
phootbag's Avatar
Secondary ignition problems usually cause misfire or poor performance during high engine loads.
Intermittent no starts usually aren't caused by a distributor rotor. Symptoms created by a distributor rotor are usually permanent, not intermittent.
Old Jun 6, 2010 | 08:53 PM
i know that its not the distributor that is making it not start. its two problems and i thought that they might be related.
1. it has a lag in the acceleration when i am driving it
2 it fails to start sometimes
Old Jun 6, 2010 | 09:18 PM
Old Jun 6, 2010 | 09:45 PM
ZMX's Avatar
ZMX
Did you gap the spark plugs properly?
Do you know the ignition coils are working properly?
Old Jun 6, 2010 | 11:32 PM
Hondaphile13's Avatar
hmm. where did you get the fuel pump and who installed it? the starting and then dying kinda sounds like what happens when you engage a fuel cut-off switch and then start the car, and the lack in pickup could be a result of a lack in fuel getting to where its supposed to be when you hit the gas. if that all started after you got the new fuel pump installed, i would get it checked just to make sure. it could be faulty. sometimes that sh*t happens.
hope that helps
Old Jun 6, 2010 | 11:51 PM
phootbag's Avatar
I have a feeling the fuel pump and filter were replaced in an attempt to correct the current symptom.
Old Jun 8, 2010 | 07:52 AM
jooky5's Avatar
I was getting weird lag and sputtering, replaced my fuel injectors. now the car runs nice, idles even smoother, starts right up.
Travis Davidson
Jul 3, 2024 05:20 PM
Laura Ilkenhans
Sep 5, 2012 08:36 PM
honvic
Dec 4, 2011 07:27 AM
atli126
Oct 19, 2003 11:16 PM
Spoonin
May 29, 2003 07:23 PM
