? about obd2 sensor
Old Jun 6, 2010 | 07:40 PM
jake00si's Avatar
Icon2 ? about obd2 sensor
The sensor that has the vacuum lines going to it..i know its an obd2 sensor but is that what its actually called?
Old Jun 6, 2010 | 07:50 PM
jake00si's Avatar
Default Re: ? about obd2 sensor
Old Jun 6, 2010 | 07:54 PM
phootbag's Avatar
What year?
I'm afraid you are mistaken. There is no sensor that I am aware of that has a vacuum line going to it.
The older vacuum operated EGR valves have a vacuum line going to them but that isn't a sensor, it is a valve. Do you have a picture or one you can use as an example?
Old Jun 6, 2010 | 08:02 PM
jake00si's Avatar
its a 2000 civic si. and i dont have a picture seeing as its night time and my iphone doesnt have flash. its right below the intake manifold and hooks into the harness
Old Jun 6, 2010 | 08:07 PM
phootbag's Avatar
Does it have two small black hoses and one two wire electrical connector? One hose going to the intake manifold or throttle body and the other going behind the engine and towards the rear? Does it say "PCS" on it?
Old Jun 6, 2010 | 08:30 PM
jake00si's Avatar
im not sure if it says pcs on it or not but that sounds like a good description of it
Old Jun 6, 2010 | 08:32 PM
phootbag's Avatar
If so, that is the Purge Control Solenoid. It is part of the evaporative emissions system. It is not a sensor. It is an electronic solenoid responsible for allowing engine vacuum to draw fuel tank vapors into the intake manifold during certain conditions and blocking vacuum during other conditions. Why do you ask?
Old Jun 6, 2010 | 08:38 PM
jake00si's Avatar
Alright well Im thinking it could possibly be bad. My other thread goes into detail about the problems i've been having with my car. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/need-help-getting-my-si-pass-smog-2758057/
Any help or suggestions would be greatly appreciated
Old Jun 6, 2010 | 08:42 PM
phootbag's Avatar
No. You would most likely have a P1457 DTC if that solenoid were faulty.
I was already following the thread to which you posted a link. I was waiting to read your findings of the Oxygen sensor voltages before posting anything.
Old Jun 6, 2010 | 08:48 PM
jake00si's Avatar
I havnt had a chance to check the voltages yet. I'll do that tomorrow after work. I was told that since i normally run a obd1 p28 that that is pretty much bypassed in a way. Now that im running the stock p2t im guessing that piece is functional again..its the only other things i can think of right now
jdm_ek_noob
Jan 27, 2014 03:04 AM
Hondatypr636
Aug 22, 2011 11:19 AM
IIXtremeHansen
Feb 4, 2008 06:46 AM
musclefella
Apr 15, 2004 09:12 AM
legendboy
Jan 6, 2003 07:02 AM
