Mild b18b questions...
Ok guys i have a b18b block that im fixn to rebuild and im looking at what i can do to it to bump the power a bit.My goal with this car isnt to be the fastest just a little faster than a stock b18b would be. So far its stock 81mm bore, stock rods and crank, arp rod bolts and head studs. Complete rebuild kit, and stock rebuilt b18 head mated to a gsr tranny in a 91 ef. My questions are would it be any benifit to run say pr3, or p30, or maybe some p72 gsr pistons on my ls rods to bump the compression a little, which pistons would be better for me?Or am i going to make no extra power with a little higher compression without aftermarket cams? i will have i/h/e, as well as a 68mm tb on the ls intake manifold..the car is going to be running on a chipped obd1 ecu
thanx and let me know if you need any extra info
ya i was thinking of going with b16 pistons due to the direct fit onto ls rods...so u think ill pick up some power with a stock head? people have been telling me that there is no point in going higher compression without cams, which i might due later down the road anyway.....will i be good with the b16 pistons with just a chipped ecu on 93 octane? any other fuel upgrades needed?
Listen to Trevor
, I'm going high comp, cam'd in the somewhat near future along with port work and what not. P30s and 403s and be very streetable. I can't think of his name off the top of my head but a guy on here made 150whp on a LS with ITR pistons, DIY port work, I/H/E and intake mani. (Correct me if I'm wrong anyone, I'm tired lol)
Wazup
13
Feb 17, 2008 07:21 AM
