blown hole through block, head still good?
Old Jun 2, 2010 | 05:29 PM
ryanangelo212's Avatar
Icon2 blown hole through block, head still good?
my buddy blew up his del sol with an ls, a hole right through the engine block. now im going about fixing it for him, i figure he'll need a new block, the head should still be okay. the timing belt didnt snap or anything, the head should be good, right?
Old Jun 2, 2010 | 05:39 PM
D16SiHatch's Avatar
Default Re: blown hole through block, head still good?
extremely unlikely. once the rod broke it's almost a guarantee the piston went flying right into the valves and destroying the head in the process.
Old Jun 2, 2010 | 05:42 PM
Matt93eg's Avatar
X2, IMO that is the likely scenario.
Old Jun 2, 2010 | 06:36 PM
dickie691986's Avatar
my buddy had the same problem with his LS. he lucked out and the head was still fine. it all depends on if the rod that broke was on an up stroke or a down stroke, but in most cases the head was probably hit with the piston. all you can do is tear it all apart and hope for dumb luck....
Old Jun 2, 2010 | 06:42 PM
forcefedferio's Avatar
this. you never know, you could be lucky. more than likely not though.
Old Jun 2, 2010 | 06:43 PM
any way to test it??
Old Jun 2, 2010 | 06:46 PM
phootbag's Avatar
You have to remove the head anyway. Send it to a machine shop for inspection.
Old Jun 2, 2010 | 06:54 PM
absolutely. do it right the first time.
pinoy_93cb7
Jul 6, 2011 01:29 PM
servion
Feb 11, 2003 10:06 PM
Brian_92GSR
Aug 27, 2002 01:25 PM
DragII
Dec 30, 2001 08:17 AM
