95 del sol electrical/fuse problem
I was driving on freeway in traffic all the sudden cars started to brake, so i braked and my cd player stopped working, got home and inspected and found out that fuse #23 15A was blown on cig/radio after putting one in it blew again, so after 3rd or 4th fuse i decided to unhook my 2 amps on 4 channel for speakers other one is 1 channel for box, while disconnecting amps i didnt disconnect + from battery and when i touched the amp with screw driver to + i had little sparks then went to disconnect the battery. Only disconnected 1 channel amp and tried my cd player it didnt blew a fuse. And all the fuses were good. But my clock, check engine light and oil light didnt work when i would start the car, i tried for the fuses again and turned the key off but turbo timer was on and kept the car running while i reached for the fuses #25 10A and #24 15A, after i pulled out fuse #25 car shut off. So i reached all the fuses under the hood and in cabin they are all good but now half of dash doesnt work
NO:
turning signals
speed
meter
rpm's
clock
inside ligth
check engine light
oil light
power windows
reverse lights
just went outside and re-checked all fuses and they are all good is there any relays or anything else that could of burned or something?
NO:
turning signals
speed
meter
rpm's
clock
inside ligth
check engine light
oil light
power windows
reverse lights
im going to try the power window and turn signal relays see if it makes any changes
were the relays at on under steering wheel fuse box for power windows and turning signal i had nothing no relays in them at all, and everything worked i swapped out fuse box from civic and there were relays for PW/TS sense there was no relay could i burned the wiring?
aleciakay2005
Jan 22, 2009 02:57 PM
Wakes4Fun
Oct 14, 2008 10:10 AM
