Radio/Clock won't work........
........I just picked a 93 Del Sol and at first my clock was working and the radio wasen't. But now my clock and my radio are not working at all. I hook all the power's up to the radio and it's just a black screen. We checked the radio by hooking it to a battery so I know it works and I have checked all the fuses and none seem to be blown.
Any help would be appreciated.
Former Moderator
Re: Radio/Clock won't work........ (Wakes4Fun)
You sure you checked all the fuses?
I'm pretty sure there's a fuse in the under hood fuse box that if blown would disable both the clock and radio.
Former Moderator
Re: Radio/Clock won't work........ (B18C5-EH2)
I'm looking in the 93 Honda Civic book (doesn't specifcially include Del Sol) and it looks like the #32 7.5amp fuse is the one in question.
The description of said fuse is the "clock/radio" fuse.
I mean that'd be one hell of a coincidence if it wasn't this fuse.
BTW the fuse number itself in your fuse box could be different seeing that I'm referencing a Civic book.
Probably one of your radio wires a short to ground. I know it has to do sumthing with the radio wire becuz my clock wasn't working, then took it to best buy to get my deck install, then my clock work.
Former Moderator
Re: Radio/Clock won't work........ (mistik_DC4)
Yes I meant to mention that if you install a fresh fuse and it too pops immediately as soon as you turn the key on then there is likely a bare wire or wiring issue at the radio.
If there is a wire shorting though the 7.5amp radio/clock fuse should be popping very quickly.
patrickg833
12-09-2017 06:42 AM
