D16A6 (Si) head gasket job
Old May 31, 2010 | 07:10 PM
Deetz's Avatar
Crazy Honda Guy
Default D16A6 (Si) head gasket job
Well, i picked up a cheap 5 speed 1990 Civic Si a couple days ago for $500. Car is in ok condition and can use a little TLC. On the way home i noticed how much white smoke was burning......head gasket
I got a new full oem gasket kit, went out to the garage and started ripping the engine apart. Turns out the engine still have the original fiber/paper type material head gasket still the, it sure was leaking, lol
Just looking for any input on the best way to clean off the old crap....what is the best way?
Here's a couple pics of the car and where i'm at.........
couple cell phone pics
Engine ripped apart
decided to wrinkle coat the valve cover while i was at it
Old May 31, 2010 | 07:28 PM
BrayzieEF9's Avatar
Default Re: D16A6 (Si) head gasket job
nice find clean even though paints faded
Old May 31, 2010 | 07:31 PM
BrayzieEF9's Avatar
have u tried a razor?
Old May 31, 2010 | 10:31 PM
~sp33~'s Avatar
EFB055
Isn't there a product called 'gasket remover'? Apply+scrape off.
Old May 31, 2010 | 11:17 PM
Deetz's Avatar
Crazy Honda Guy
I haven't, is that what Honda dealers use?
Not sure, that's why i am asking. I know all the "newer" head gaskets are metal, and so easy to deal with when changing over. I posted this one, because it was original, never been changed....the style that Honda went away from. It just leaves so much material behind apon removal after all of this time
Old May 31, 2010 | 11:22 PM
Deetz's Avatar
Crazy Honda Guy
The underside of the head had that junk all over it too, you might be able to see what i am talking about
Old Jun 1, 2010 | 12:04 AM
~sp33~'s Avatar
EFB055
Not all 'new' head gaskets are metal. Most that i know of are the same type as your engine had on there, when i did a HG on my Cressida i used that soft type. They have their advantages, for one they form a better seal if your mating surfaces aren't 100% true, which is often the case with old heads.
Old Jun 1, 2010 | 11:34 AM
D16SiHatch's Avatar
i tried using a gasket remover when i did an a6/y8 swap and it didn't work worth a ****. tried scraping at it, used a razor, nothing worked very efficiently and i had been at it for probably 2 hours.
then i got an idea and a buddy of mine lended me an angle air grinder with a fairly high grit pad. it worked awesome and took all the old material off real fast and left a nice finish for the new gasket to mate to. i know this method isn't recommended by some, but if you're careful and don't gouge the surface, or use to low grit of a pad, it should work fine.
i've also heard people say these work pretty well, but i haven't used one personally so i can't say. 3m roloc bristle pad i believe is what it's called
http://www.youtube.com/watch?v=2lM7IgqMAiA
Old Jun 1, 2010 | 01:48 PM
Deetz's Avatar
Crazy Honda Guy
Wow, that's pretty cool. I'll look into that, thanks!
Old Jun 1, 2010 | 02:45 PM
lunalink's Avatar
D16 si hatch beat me too it lol.
Old Jun 1, 2010 | 05:22 PM
D16SiHatch's Avatar
shore thing man
indeed i did :p
Old Jun 1, 2010 | 06:13 PM
1 Civic I's Avatar
Thats a nice find i wish i could find one for that cheap even a shell. must be 2nd coat of paint. handles are painted red? arnt they all black?
Old Jun 1, 2010 | 06:54 PM
Deetz's Avatar
Crazy Honda Guy
Actually, here in Canada, "ALL" 1990 and 91 Civic and crx Si models came with both painted mirrors and door handles. ALL EF's in Canada also have pillar mounted seat belts too
Old Jun 2, 2010 | 04:29 AM
sde780's Avatar
nice pickup
I used a razorblade on mine, little by little. But it came out clean
Old Jun 2, 2010 | 11:38 AM
BrayzieEF9's Avatar
not sure if the dealers uses razor blades to removed em,but thats what me and my buddies use,its like the same concept of removing stickers off your window with a razor blade
Old Jun 2, 2010 | 11:53 AM
D16SiHatch's Avatar
razor blades not only suck to use, but you run the risk of nicking the block. using the angle air tool allows you to achieve a nice even surface, not to mention it takes a hell of a lot less time.
Old Jun 2, 2010 | 12:01 PM
BrayzieEF9's Avatar
yeah thats true,but not everybody can afford air tools though.
Old Jun 2, 2010 | 12:04 PM
jbmmfrie's Avatar
ewwww gross!
THE GREEN CRX//
Feb 9, 2014 06:35 AM
fudo1252
Feb 24, 2008 06:20 PM
DelSol-B-18
Apr 8, 2005 06:46 AM
tilt
Nov 29, 2002 02:01 PM
Shea-bird
Nov 12, 2001 02:22 PM
