Hondata S300 Tune is gone
Well, I was stupid after about 2 years of having a great tune on my vehicle and thought why not check out the Launch Control settings? Well I downloaded the data from the ECU turned on the Launch Control settings and uploaded back. Turned my vehicle on and was starving for gas. I backed up the file soon as I downloaded the data from the ECU and thought well this is no problem i'll upload the data back. After uploading it back still would die because it was starving for gas.
I didn't mess with the tune at all I'm confused on how I screwed it up I am quite sure that it is screwed up though. Car is a B16 Turbo Setup. Anyway how can I get this thing at least drivable to a shop to get it tuned or best case scenario get the tune back....
Thanks
Thanks
Hondata themselves admit that uploading the tune from the ECU to the tuning computer is buggie at best and will fail/corrupt the file more times than not.
Changing the Low Speed Ignition Table to:
12.5 12.5 12.5 12.5 13
From all 16's
It's now idling properly at around 700 RPMS and runs the way it use to. All the other values saved from the intial upload. I just changed those table values everything is working properly the ECU had a BAR0 Code 13 but other than that runs just like before. Maybe the settings I changed had no change on the car either? Maybe it just corrupt uploading back and finally it took it? Suggestions?
From all 16's
