95 EX Throttle cable P/N
Old May 24, 2010 | 08:47 AM
cpl rampage's Avatar
Default 95 EX Throttle cable P/N
So after installing my new IM and TB i found the adjusting nut on the end of my throttle cable is frozen on, and cant be adjusted. I looked online for the replacement, but the honda drawings are not exactly clear which cable is for what. The drawing shows 3 cables, one being a cruise control cable, and the other two being labeled as throttle cables, one looks shorter then the other. Im guessing it is for a different model (cx vs ex etc.) the two part numbers are:
17910-SR3-A51
and
17910-SR3-A91
Any help is appreciated.
Old May 24, 2010 | 09:11 AM
Sr420Det's Avatar
Default Re: 95 EX Throttle cable P/N
What motor and intake manifold are u using? u have a manual tranny right? did the car used to be a auto? Did u swap the accelerator pedal?
Old May 24, 2010 | 09:12 AM
Sr420Det's Avatar
hate to tell u this but on every aftermarket im Iv used i had to bend up the throttle cable bracket to get it to work properly
Old May 24, 2010 | 09:15 AM
Sr420Det's Avatar
I think the 91 is what u need, looks like the 51 is for a automatic.
Old May 24, 2010 | 09:19 AM
Sr420Det's Avatar
https://honda-tech.com/forums/showthread.php?p=39840393 This one says use the 51 so I dunno
Old May 24, 2010 | 09:28 AM
Sr420Det's Avatar
Put them in majestic and they both are the same.
Old May 24, 2010 | 09:35 AM
its a manual car, manual trans, stock peddle, S2 intake and TB, i know i need to bend the bracket to fit/align correctly, and i did that to some extent, but to get the tension right i need a new cable.
I got those part numbers from bernardiparts.com they are usually cheaper then majestic, and actually give u the P/N's.
I would think it is the A51, just because the A91 looks really short in the picture.
Old May 24, 2010 | 07:00 PM
Sr420Det's Avatar
Thats what the other thread said. The cable is cheap, u can just order from ur local honda dealership. I know it wil b ten bucks more but u can return it right then and there with no shipping charges and u could talk to the parts guy to help figure out what u need. Id go with the a51 like u said.
Old May 25, 2010 | 04:02 AM
Yeah thankfully bernardi honda is local to me haha, i get the online pricing and the ability to return without shipping lol. i will order the cable today.
Old May 25, 2010 | 05:57 AM
kaiba's Avatar
EX/SI/VX are all the same.
4g4dcruisin
15
Jun 17, 2010 06:51 AM
Mixmasta
Jul 14, 2008 06:30 AM
SohcVtaak
Sep 13, 2007 08:34 AM
billk2k
Feb 11, 2003 02:19 PM
Simple
Jan 13, 2003 09:44 PM
