Cant get new blox TB to fit, need help.
after i got everything put on i went to connect the throttle cable and it didnt reach.
even with the cable as loose as it can get on the intake mani bracket im still about a half inch away..
so basically when i connected the cable the throttle body was about half throttle..
what do i need to do?
an adapter wont help if there's not enough reach to the cable, the way you described it is that the cable isnt long enough so the tb won't completely close.
are you sure you have the right tb? are you sure you routed the cable properly? i just can't imagine the scenario where a cable wouldn't reach the tb.
yeah everything is mounted right and its a B series Blox tb. and i have a b18b and the cable from that motor..
I think all i need to do is move the throttle cable bracket over one hole i looked at my friends today and thats how his is. So ill try in and let you guys know.
my bet is the outer sleeve under the dash on the accelerator pedal bracket has unseated itself causing the outer to be longer that it should be, crawl under and check it.
you didn't rent the cable stretcher tool ???? .
