Blown head gasket d16a6 help
Old May 23, 2010 | 12:00 PM
AlfieRoach's Avatar
Default Blown head gasket d16a6 help
problem solved
Old May 23, 2010 | 12:31 PM
AlfieRoach's Avatar
Default Re: Blown head gasket d16a6 help
sorry bout the grammar my touch sucks For typing
Old May 23, 2010 | 12:58 PM
AlfieRoach's Avatar
Old May 23, 2010 | 01:41 PM
1991civicsi's Avatar
install new Z6 gasket, ur done
Old May 23, 2010 | 01:51 PM
AlfieRoach's Avatar
Thanks man what about head bolts
Old May 23, 2010 | 02:08 PM
DCRB's Avatar
replace the head bolts and have a machine shop check your head for warpage. plus you can have them put a fresh surface on it
Old May 23, 2010 | 02:24 PM
freydaddy's Avatar
might as well get a valve job while you re there.
Old May 23, 2010 | 03:39 PM
AlfieRoach's Avatar
Old May 23, 2010 | 03:49 PM
dr_latino999's Avatar
Replace them with ARPs IMO, more money but they are reusable; and studs just make the world a happier safer place.
Old May 24, 2010 | 01:27 PM
AlfieRoach's Avatar
update so finally got to check it out heres the run down, i was on the highway and as im acclerating all of a sudden the car started popping from the exhaust and as i was acclerating it was losing power, so i down shifted to see if it was just the tranny or clutch slippin but it kept dying down, pulled over and eventually the car died i check the oil and i thought i saw lil coolant in there but it couldve been the sun messing with my eyes, but when i check it now theres no coolant in the oil though my cuzn said he smells gas in the oil. i tried smelling but i have a bad sense of smell and when i tried starting it, it cranks and it will pop from the exhaust but it wont turn on any ideas ?
Old May 24, 2010 | 02:44 PM
AlfieRoach's Avatar
cant tell if oil smells like gas , bump
Old May 24, 2010 | 04:28 PM
Timing? Did you check your plugs? Did you pull a compression / leak down test to make sure you put it back together again right.
primerpimpin
Oct 23, 2009 06:49 PM
alupso
Feb 27, 2008 01:09 PM
JTCdudeman
Sep 29, 2005 05:42 AM
G2Crash
Jun 13, 2004 02:56 AM
civicmatt
Nov 27, 2003 06:13 PM
