Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Brake cooling after lapping on road course
Old Sep 12, 2002 | 01:24 PM
EleanoR's Avatar
Default Brake cooling after lapping on road course
I am just wondering what you guys do to prevent your rotors from getting warped.
I have seen people say that they take a full cool down lap and go easy on the brakes and just let them cool down.
I have also heard people say they drive around in the pits to cool them down.
I also hear of people parking the car and not using e-brake and let the car sit.
And the last method i hear is people parking their car and moving the car a few feet every 5 minutes or so to let the pad move to a different part of the rotor as to not sit on that exact spot with all the heat trapped inside that area.
So what is YOUR method?
Mike
Old Sep 12, 2002 | 01:37 PM
SPiFF's Avatar
Default Re: Brake cooling after lapping on road course (EleanoR)
Hawk pads and Brembo rotors for 3 years of track days. Never a warped rotor. Cracked a few, but never warped.
Old Sep 12, 2002 | 01:48 PM
bulldog_RS20's Avatar
It depends on how hard I ran on the track. If it's a full blown race, and I come off real hot - I'll put the car up on stands, remove the wheels and rotate the hubs every couple of minutes till the cool down a bit.
A Porsche guy gave me this tip when bedding new pads to new rotors:
Jack the drive wheels off the ground. Use stands and block ground wheels. Start engine and let the car run in second gear at idle for about five minutes.
This ensures the rotors and pads are cooled evenly and that thee isn't any heat-trap on the rotors. I only do this when using new rotors for the first time...
Greg
Old Sep 12, 2002 | 02:58 PM
johng's Avatar
All of the above.
Use your cool down lap for just that.... to cool things off. If possible, I'll take the cool down lap without using the brakes at all.
Old Sep 12, 2002 | 04:21 PM
Blue Liquid's Avatar
New User
Mike, I do all of those things you mentioned after each lapping session.
Old Sep 12, 2002 | 04:46 PM
Ben Ogle's Avatar
Default Re: Brake cooling after lapping on road course (Yellow R #01-0468)
Aparently there is no such thing as a warped rotor, but you do need to cool your brakes. a guy on G2IC posted this:
http://stoptech.com/whitepapers/warped_rotors_myth.htm
Ben
Old Sep 12, 2002 | 08:42 PM
GRM Scott's Avatar
25 Year Member
Default Re: Brake cooling after lapping on road course (johng)
yeah, try not to touch the brakes on your cooldown lap...i've heard this is an exercise they use at some driving schools as well, it's interesting how you do when you can't use the middle pedal.
Old Sep 13, 2002 | 05:45 AM
Evan55's Avatar
Default Re: Brake cooling after lapping on road course (Aleph)
I take my brake cooldown a little to the extreme, but when I get only 2 weekends out of a set of $200 'race' rotors I think its pretty justified.
I dont touch the brakes on the checkered lap, then I drive around the pits, and on to one of the access roads for at least 5 minutes, usually 10. When I pull in to park the car I dont touch the brakes, i either coast to a stop or lightly pull the e-brake (my car uses an internal drum for the ebrake btw) then about every 5 minutes I move the car a little bit
Old Sep 13, 2002 | 06:43 AM
Knestis's Avatar
Default Re: Brake cooling after lapping on road course (Ben Ogle)
"A guy"? A god. Carroll Smith is the racing guru that none of us will ever be. If you haven't read the "to Win" series of books and are driving your car on a race track, you are kissing your sister.
Kirk
Jackson
22
Jul 23, 2013 12:53 PM
avio
May 15, 2010 10:06 AM
lowRIDAH
12
Sep 19, 2005 09:41 AM
aesthetics82
10
Sep 9, 2004 06:54 PM
MaddMatt
Mar 1, 2002 02:48 AM
