pros and cons of crower springs and retainers
Old May 20, 2010 | 08:49 PM
insaneconceptz's Avatar
Default pros and cons of crower springs and retainers
i am trying to figure out if i should use the crower springs and titanium retainers, and which valves to go with. I was talking to one of the guys over at ferrea and was explaining my build to the guy to figure out which valves to go with and when he asked what springs and retainers i had he was like be careful. Crower stuff and very tight tolerances and if you go over just the slighest bit i will float valves. So now i am not sure if i want to even keep these things i need so input on what other people are using in the gsr head. Also with this build i am not planning on going over like 9200
83mm sleeved block
JE pistons
eagle rods
crower springs and ti retainers
stock gsr cams for now
precision .70ar cold .63 hot
s300
a1000 pump -10 line
1600cc precision injectors
e85 fuel
Old May 20, 2010 | 09:11 PM
narfdanarf's Avatar
Default Re: pros and cons of crower springs and retainers
On my last build I made in the 500whp range on 30lbs, and on gsr cams for 26,000 miles my crower springs/stock retainers/stock valves did fine...I revved it up to about 9500 daily.
With that being said I have ferrea in my new motor for peace of mind and because I make significantly more power/revs now.
Old May 21, 2010 | 02:34 AM
oneqkfodo's Avatar
When we had our old LS head on our motor, we were using Crower Springs/Retainers with Ferria Values and didn't have any problems. We were revving the motor to about 9k also.
Old May 21, 2010 | 02:56 AM
1992Si's Avatar
You'll be fine, make sure they are installed at the correct seat pressure and you should not have problems. Tight tolerances is a good thing.
Old May 21, 2010 | 09:18 AM
redboost10's Avatar
hey buddy, we were using crower springs and retainers with our itr cams taking it to 10, 200 rpm the last three previous years. we never had a problem, but when we had the head reworked by portflow, tom upgraded the valvetrain as well. this year we switched to everything supertech and you know how big the cams are this year.
Old May 21, 2010 | 12:36 PM
boostek9's Avatar
im running the crower stage 2 turbo cams, springs and retainers
going on 3 years revving to 8800, made it into the 10's and very reliable set up
Old May 21, 2010 | 01:35 PM
h22 civic's Avatar
crower springs and ti retainers with ferrea valve on a turbo h22 multiple 9000 rpm dyno passes,,track passes and street use and no prob yet ..........now i'll prob drop a valve lol
Old May 21, 2010 | 02:07 PM
B18c1turboedEK's Avatar
I was running supertech,until 2 broke for no reason while the car was warming up.Im going Ferrea now, cant go wrong there.
jrp355
Feb 22, 2013 06:31 AM
p0gi_b0i_integra
Jan 25, 2008 08:33 AM
tunerraceteam
67
Jun 22, 2007 03:09 PM
DC4 Rasta
Mar 19, 2007 12:30 PM
Tru
Mar 5, 2006 04:42 PM
