LS turbo question
Old May 20, 2010 | 11:08 AM
w3aselll's Avatar
Default LS turbo question
i was wondering if i could turbo my stock 1990 integra da9. it has about 185000 miles on it. If i turbo it do i have to build my motor first or can i just leave it bone stock and turbo it?
If i could turbo it then what turbo should i get? I dont want anything too crazy just wanna have a turbo car.
The integra is mostly stock besides an aem intake. If i turbo would my motor blow?
THANKS FOR HELPING.
Old May 20, 2010 | 11:19 AM
dunked dc's Avatar
Default Re: LS TURBO QUESTION
get a motor with less miles or rebuild urs for sure, 185k is up there for boost and if ur gonna leave ur internals stock i wouldnt push over 8 psi prolly less
Old May 20, 2010 | 11:26 AM
njmad's Avatar
research first man.
Old May 20, 2010 | 11:28 AM
w3aselll's Avatar
i tried
Old May 20, 2010 | 11:35 AM
turbotegy10's Avatar
i turboed my stock b18 motor and blew one of my piston rings with only 90,000 miles on motor and about 10psi of boost. you can build an entire bottom end for boost for about a $1000. i did and now i can run about 20-23 psi of boost with no problems. i would just build the bottem end and save your self the time and headache. and as far as turbo's i am running a 50trim turbo and love everybit of it. if you are looking for an entire kit try treadstone turbo's reasonably priced and everthing you need.
Old May 20, 2010 | 11:41 AM
w3aselll's Avatar
thanks
Old May 20, 2010 | 11:43 AM
w3aselll's Avatar
so no turbo for me? =/
Old May 20, 2010 | 11:47 AM
TheZooKeeper's Avatar
Save up, build it up nice, do it right
Old May 20, 2010 | 03:35 PM
20-EM2-05's Avatar
Keep your motor use it for daily driving.
Buy a new one to build on the side.
When it's done building go and install your turbo and drop the motor in.
As for your old motor. I'd keep it and rebuild it again and either put it into shell.
Old May 20, 2010 | 03:50 PM
hybrid90's Avatar
This!
Old May 20, 2010 | 05:28 PM
Jimmy's Avatar
Global Moderator
Default Re: LS turbo question
go to the forced induction forum and do lot's of reading.
check out the [faq] threads and search
94Eg_SnatchBack
Oct 25, 2011 12:41 PM
streetcartuner
Feb 6, 2009 07:33 AM
ls integra mike
May 19, 2008 05:37 PM
Doostur
Oct 3, 2004 09:52 PM
redluder
Jun 29, 2002 02:19 PM
