can't pull off camgears !!! HELP!!!
Old Sep 12, 2002 | 11:10 AM
austrian type-R's Avatar
Default can't pull off camgears !!! HELP!!!
Damn! My cam gears are not going off! What the hell..... what should I do? I have to turn the bolt in counter clockwise direction, right?
This happens to my engine:
https://honda-tech.com/zerothread?id=274704
Old Sep 12, 2002 | 11:31 AM
uNF$@#!'s Avatar
Default Re: can't pull off camgears !!! HELP!!! (austrian type-R)
got seized?
use some wd40
[Modified by Soup ****, 3:32 PM 9/12/2002]
Old Sep 12, 2002 | 11:35 AM
BlueR's Avatar
Default Re: can't pull off camgears !!! HELP!!! (Soup ****)
may i suggest an impact wrench... Just Kidding
blue- who will run like forrest as soon as he hits the post button
Old Sep 12, 2002 | 11:37 AM
tonyxcom's Avatar
Maybe you shouldn't be the one changing it if you have to confirm which way to loosen a bolt
Old Sep 12, 2002 | 11:41 AM
integRated109's Avatar
Default Re: can't pull off camgears !!! HELP!!! (BlueR)
mine was really stuck on there, i had to use a good sized breaker bar
Old Sep 12, 2002 | 11:43 AM
sgT's Avatar
sgT
Impact for removing is fine.
Old Sep 12, 2002 | 11:49 AM
Default Re: can't pull off camgears !!! HELP!!! (sgT)
counter clockwise, like the bolt on the crankshaft, right?
Old Sep 12, 2002 | 11:56 AM
Dodger2940's Avatar
Righty tighty, lefty loosy
Old Sep 12, 2002 | 11:57 AM
Racebrewer's Avatar
Counter clockwise to loosen. Normal thread.
John
Old Sep 12, 2002 | 12:13 PM
JPP's Avatar
JPP
Try a 17mm key with a "closed"end. Use the closed end on the bolt and hit (not like a maniac) the other end of the key with a hammer several time. The impacts may loosen the bolt. As a tip, keep a little torque counter clockwise on the bolt with the key as you hit it with the hammer. it is easier if the timing belt is stil on so the whole camshaft doesn't rotate (unless you have stock camshaft and you can "pin them in place".
[Modified by JPP, 4:19 PM 9/12/2002]
alvarez.esteban
Nov 26, 2012 11:08 PM
BILLisCHILL
Feb 27, 2008 12:01 AM
projsectEF
Sep 21, 2007 03:53 PM
Adachi
Mar 3, 2003 08:04 PM
Ludester
Mar 2, 2003 07:05 AM
